OT: Anyone considered a mini-split system for their garage?
Re: OT: Anyone considered a mini-split system for their gara
I had one of those heaters on a propane tank. It was in the explosion and didn't catch on fire. There was still propane in it even. No, I did not save it.
Mark in Toronto wrote:^^^^Personally, I would not feel comfortable using that heating element and a 30 lb tank in an enclosed space.
It lacks basic safety features such as low O2 auto shut off.
:laugh: I wouldn't exactly call my garage "an enclosed space". Drafty as a corn crib. ;) It was a cheap solution that has come in handy, but I don't really use it often enough for it to be a huge concern. So far maybe twice this season is all.
Mark in Toronto wrote:This winter I'm using the Mr. Heater Big Buddy. It's portable, 18,000 btu's so it can easily heat the garage to 60 + degrees and uses dual 1 lb cylinders or you can attach a hose and hook it up to a 30 lb tank.
That looks like a decent option, but if I were going to do something different I'd probably opt for something that doesn't require a tank and doesn't sit on the floor. Maybe an electric heater like this one:
Mounts up high, doesn't clutter the floor, has a fan to move the warm air around, and no danger of CO2. There are also some wall-mounted non-vented propane/natural gas heaters that would work well for about the same money. Neither are likely to happen this season anyway; we'll see what next year brings.
WilNJ
Post by WilNJ »
The big difference in the OPs solution and the others offered is that he can maintain the garage at a desired temp even in an unoccupied setting.
demetk
Post by demetk »
davintosh wrote:Working in a cold garage in SD isn't much fun either. So far all I've used for supplemental heat is one of these;
No need for thermostats; if it gets it warm enough in there to keep water-based stuff from freezing, that's as good as I need it. Too bad most of its heat just goes up into the rafters of the garage. Using it does make me a bit nervous though. It's never left unattended.
I also used one of these temporarily when I needed some heat in the garage or in my unfinished addition but I always kept an eye on it. So, what are the products of combustion with them? I'm assuming since they're not vented, CO would be a concern.
The electric resistance heaters would be a solution when used with a thermostat but straight resistance heat is the most expensive heating option around here. A heat pump beats natural gas, propane and oil heating in terms of cost to operate. Natural gas heating would be my choice if I had that option but I have no natural gas lines around me. I do have propane though and even though it's an expensive option, I would consider using a small direct vented propane heater as an aux backup to the mini-split when it got bitterly cold.
Interested to see what others are using, so please post up.
waynet1
Post by waynet1 »
demetk wrote: Interested to see what others are using, so please post up.
:D :cool:
davintosh wrote:Maybe an electric heater like this one:
Yes, electric heat is a good option. Once the Big Buddy has warmed up the garage, I have two ceiling mounted electric quartz heaters to maintain a comfortable temperature.
The quartz panels are much more energy efficient when compared to conventional electric heaters.
demetk
Post by demetk »
:D :cool:
bastard. I think I need to move there.
:D :cool:
Kaleighphourkneuns. :roll:
Justin_FL
MyE28 IT Guru
MyE28 IT Guru
Post by Justin_FL »
demetk wrote:bastard. I think I need to move there.
Err, unless you like sweating your ass off even at X-mas, it really is highly overrated!
I do need an A/C system in the garage.
waynet1
Post by waynet1 »
That is very true.
demetk, I would much rather be in your beautiful neighborhood and house tinkering with the heat in your garage then being here any day. I really dislike it here, but I dislike being cold even more. I wouldn't recommend living here to just about anyone, unless you're in the yacht industry, even then it is difficult.
Justin, you might want to try one of those free standing A/C units. I've seen them pretty inexpensive at Big Lots.
demetk
Post by demetk »
waynet1 wrote:I wouldn't recommend living here to just about anyone, ...
Crap. That pic you posted looks a lot like heaven to me.
waynet1
Post by waynet1 »
Oh it's a great place to visit. Living here is a very different thing, it is a city with all the things that most people dislike about cities.
You just can't beat the weather though IMO.
I've been told rats live in those trees. I haven't gone to the trouble of verifying that during my brief visits there, and not sure I'd even want to try. Besides, I kinda like the trees that lose their leaves in the fall then grow them back in the spring.
