What ^^^ said about rocker pads. If in your case several are worn are they concave in the contact patch instead of convex. If your cam shows signs of wear and any rockers also you really should replace it all. Alternative is to just keep and eye on it and use a quality oil.trevmmeister wrote:Readjusted today. Per the bentley to the letter. Runs fine, idles perfect, and generally feels and sounds better. Then again if it didnt, whats the point eh. But I think I am going to go through all of the rockers, eccentrics, and valves and see how many could use replacing. not a full rebuild, just a refurbish. There are some rockers that have worn through the pad and are starting to make contact on the body of the rocker. A couple cams with grooves in em too. A few eccentrics were oddly off-round.
Also, quick question. Will the Bosch SR95X starter fit a B34? Or is it for B35 only?
How many miles on this motor and any intel on the oil it's been running. Many will say that running too thin and low zinc oil for too long intervals will wipe the cams in these cars. In other words the local quickie oil change and longer service interval is very bad over the long run. If it had been treated with a low zinc 5w-30 called out in most newer cars of the past 10 years for example.
