Coolant light came on during my way home from work tonight, and I had the house to myself, so I went and replaced my heater valve, the source of the leak. This is what came out:
So far, no leaks, but I only had an around-town shakedown to go see a friend's new digs on the other side of town. Tomorrow will show whether the repair was successful in stemming my coolant leak. I also wonder if this was the culprit behind my heat loss at extended high-RPM cruising.
I also got tired of the car marking its spot on wet days...it's embarrassing at work. So after I got the cooling system buttoned back up, I put it up on ramps to check for any major oil leaks. My head gasket is seeping, I knew that, but not enough to cause a major drip. Earlier today, I dragged my finger across one of its rainbow spots and it was not oily, so I doubly hoping it was just the coolant leak making its presence known.
Then, I fixed a tiny gas leak on the feed line to the fuel rail. It was small but I would get a whiff of fumes every now and then - I thought it was the charcoal canister. What's weird is that the hose clamp wasn't really that loose, so maybe I need to cut that end off or replace the whole hose. But when I tightened it, the leak did stop.
Last, I started to look into the idle surge a little more, despite the 5k-old O2 sensor, used AFM, valve adjustment in the last year/5k miles, new ICV hose, used ICV...I checked the throttle plate clearance and its around .0015. Bentley's gives that as the 528e spec, I don't know if its different for the 535i, which they just give as a "eh, it's not touching the walls" spec (my paraphrase). While I had the engine running, I investigated if bumping the butterfly valve just a tiny bit would smooth out the idle - currently it pulses from 6-800 rpm - and it did. Couldn't tell you what the RPM were but probably around the 800 mark going by the sound (since it was like the high side of the pulse). Unfortunately that's when I got the call from my friend that he was over at the new house, so I just cleaned everything up and went over there. I just got done w/ checking the Bentley's to see where the throttle stop is (I was looking and couldn't find it....it's on the cable)
She's getting there little by little. Good news is that she's 2k miles into the swap already (I can't believe it) and things are going relatively smooth.
