slimdevil27 wrote:With all three variations of MAF, AFM's and chips....you are still running lean with the O2 unplugged.
Our ECMs have a biased O2 signal. If you test the harness side of the O2 sensor with the engine running, you will see .5 volts. If the O2 is dead or unplugged it defaults to .5 or stoich. If everything is working and adjusted correctly unplugging the O2 sensor would give you a reading of 14.7 AFR. The O2 sensor then drives this lower or higher as it ocilates. A good O2 should sweep about every 1-1.5 seconds between high and low. Further it should be able to go below .2 volts and above .8 volts when artificially leaned or enriched. At 2500 rpm is should oscillate between high and low 4-7 times per second (IIRC from my snapon vantage). Because or signal is biased at .5 volts, unplugging the O2 will default the ECM to a perfect middle reading as the input signal. Any adjustments that effect air/fuel ratios should be done with the O2 unplugged and monitoring the O2 with a VOM or using a wideband. Make adjustments until your O2 is averaging .5 at 2500 rpm.
Good info. Thanks. In my case forget about reading the actual O2 sensor, I have a wideband in it's place.
Have you verified that the CTS is working in the correct range? If it was biased towards a hot reading the result would be a constantly lean mixture. That would drive the mixture lean at all engine speeds where a vacuum leak would only be apparent at lower engine speeds. Low fuel pressure would have the same effect, lean at all engine speeds.
Yes, but last summer. I will do it again asap. Great point.
Have you tested the fuel pressure? Are you running stock injectors? Does turning on your headlights affect the fuel mixture or idle oscillation? Have you cleaned all the grounds?
Yes, I have an AFR with a gauge. Yes, stock injectors. No, headlights do not seem to affect mixture. Yes, my grounds have been cleaned multiple times (for other reasons).
What I'm getting at is nothing you have tried has resolved the single issue of being lean with the O2 unplugged. I believe that is the biggest flag that something else isn't right. The only other sensor that will drive the ECM lean (or rich) like that is the CTS. As for mechanical problems that would do the same...it's limited to fuel pressure and injector flow (plugged or wrong size), electrically is would be corrosion, AC leakage from a bad alternator diode, a bad ECM...
I have 3 ECUs. When I changed chips above (and in my dyno runs) I didn't swap the chips in one ECU, but changed ECUs. For now I rule out the ECU.
AC leakage from a bad alternator diode...hmmm...how would one test that? What other symptoms might that cause?
I agree something else isn't right. I appreciate you leaving me some breadcrumbs that might help figure it out. Remember, though, it's all academic as this engine is coming out of this car this weekend and almost every related part is being replaced.
You can borrow the ECM out of my 535. I have a fuel pressure tester, a Snapon Vantage Scope
I'd love to play with that scope!
..........and a damn engine hoist.
