Page 2 of 10
Posted: Apr 05, 2013 5:05 PM
by Eddie in TO
beliq wrote:The color name is after a track - the Malaysian F1 track which is in the town of Sepang as well (Sepang International Circuit).
Just like Daytona, Imola, Laguna, Dakar - i believe that in the late 90s BMW moved away from the traditional German names of colors to the track named ones.
Thanks for clarifying.
Now I know
Posted: Apr 05, 2013 6:47 PM
by VTR1000SP2
Yep, thanks for the 411.
Posted: Apr 08, 2013 3:16 AM
by Pedi
Yeah, the Sepang color looks nice!
Here is a live pic of my E28 with sepang:
Posted: Apr 08, 2013 6:22 AM
by RoyW
Pedi wrote:Yeah, the Sepang color looks nice!
WOW... very nice.
I knew that color would look good on an e28, didn't know anyone had tried it, but it's great to see. Thanks for sharing!
-RoyW
Posted: Apr 08, 2013 7:50 AM
by Pedi
Yeah, it looks nice on E28.
If you feel for it, you are welcome to look into my build-thread.
Posted: Apr 14, 2013 10:56 AM
I don't spend near enough time in Eye Candy.
This will keep me coming back.
Hoping the rest of your trip is a success.
Posted: Apr 14, 2013 11:18 AM
by uter
Based on Pedi's picture, I'd have to vote for Sepang with shadowline trim.
Posted: May 09, 2013 5:37 PM
by RoyW
Well, I (we) finally got back to doing some work on the "Project Sepang" car after taking most of April off, i.e., TX trip, PA car show, some detailing jobs, etc., etc. I did meet Todd (TCD) on my way back from the PA show and picked up my TCD Stage 2 turbo kit from him... about 10 boxes of parts...awesome!!
While I was out of town for the TX roadtrip, the car was up at VSR for R&R of the full suspension (upgraded) and steering components, plus a general clean-up of the rear and front sub-frame parts. VSR also modified the rear sub-frame for adjustable camber and toe-in; installed new M5 rear diff mount; R&R center support bearing: reinforced front sub-frame at the steering box bracket; installed M5 steering limiters on front sub-frame; installed new M5 front & rear sway bars with new welded-in M5 brackets & bushings; replaced all brake lines with SS ones; R&R e-brake shoes, cables, and associated hardware kit; replaced fuel filter. I also picked-up the refurbished head at VSR and the oil pan and filter housing with their new "fittings" for the oil lines.
Got the car back to my barn at the end of April and I finished cleaning-up and painting the block. Then, last weekend my "mechanic" friend Steve, my nephew Brad, and I got the timing components all replaced with new ones (finally got the hub to come off... with a proper gear puller!); installed the fan clutch in the newly painted red fan that I scored over the Winter (I used SEM to refresh the red fan); installed the oil pan & gasket; and, installed the head with the ARC bolts set and the head gasket from the TCD turbo kit.
Finally, we went to install the brakes and discovered that I had two left rear calipers (no right one!), so that ended that attempt to complete the upgraded brakes on all four corners
When I get the "right" rear one (and return the extra left one) I'll be painting up another caliper! If you look at the picture I previously posted in this thread of all 4 calipers after I had painted them, you'll see the mirror image front ones and the exact same rear ones (two lefts)... surprised no one noticed that, including me, at that time!!
Next on the agenda (in a couple weeks) is the install of the filter housing (needed to order that gasket, and a few other engine gaskets/seals, which I discovered I had not done); lots of gasket/seal replacements; installation of the M5 lightweight flywheel and TCD kit clutch; installation of some more turbo kit bits; and anything else that's easier to do while the engine is still on the stand. Then, it'll be time to drop the M30 back in the car!
Hope to get this all done by mid-June...we'll see!
-RoyW
Posted: May 11, 2013 1:44 AM
by leadphut
Posted: May 11, 2013 8:45 AM
by RoyW
It didn't start out this way in my plan and in my head (I was thinking more clean, euro-look DD with a "boost"), but as things tend to happen over time and as plans evolves, etc., etc., I think this has the potential to be one of the coolest, fastest, resto-mod e28s on the planet... when all is said and done!!
Posted: May 11, 2013 10:54 AM
by Coldswede
NICE!
Roy, what did you do to the oil pan? Is it soda or bead blasted or what? I like the mat finish on it.
Posted: May 11, 2013 11:07 AM
Saaaaa-weet!!! Spell check didn't like it, but it fits, so it's stayin'.
Posted: May 12, 2013 7:19 AM
by RoyW
Coldswede wrote:NICE!
Media blasted and then clear-coated with a matte clear.
-RoyW
Posted: May 14, 2013 5:25 PM
by GaAlpinaOwner
She is shaping up very nice Roy.
It looks like a fun project !
David
Posted: May 16, 2013 10:58 AM
by Eddie in TO
Wow, you're really moving along Roy!
Nice job on refinishing the parts including the valve cover.
Keep the updates coming!
Posted: May 17, 2013 4:46 PM
by davintosh
Looking good, Roy.
I really need to hang out in Eye Candy more often.
Posted: May 17, 2013 10:12 PM
by igotbank
Roy, this thread is very inspiring. I just picked up a 85 635csi 5spd with the intent on doing a resto mod. Recent home roof leak and renovations put it own the back burner. I bought it non running for cheap and got it fired up in a weekend with help from a friend. It hadn't been running in 2.5yrs. How did you come up with that color choice? I'm anxious to see the end result tho it won't be cooler than your old track car
Posted: May 26, 2013 5:46 PM
by RoyW
Posted: Jun 14, 2013 8:53 PM
by RoyW
Well, things have slowed down on the project car, as my schedule and those of my very capable helper haven't been lining up. But last weekend a couple of us did make a little progress.
Here's a summary of what we did (and a few pictures below):
- got the new rear caliper bolts and did up the rear brakes.
- got the new missing nuts and o-ring to complete the install of the oil sensor in the oil pan.
- installed new spark plugs
- installed the freshly powder-coated valve cover with new gasket
- and, most importantly, got the right oil fitting from TCD for connecting the oil supply line (from the oil filter housing) to the turbo, and then we got that installed... it was not an easy job with the turbo and manifold already on the block!
- also got the waste-gate installed and mocked up the inter-cooler and intake to see and try to figure out where all the line, hoses, etc., needed to go
- removed A/C lines to make room for turbo piping (will replace these hard lines, with flexible lines from the TCD kit)
- next, we tried to figure out where the two small oil coolers could mount, but with no front-end on the car, didn't make much progress. The euro bumpers and euro valance make it a little more difficult to figure out where to locate them, as the U.S. fog light area in the U.S. valance is generally where they'd go. I may have to sacrifice A/C and use the area where that radiator sits for a single larger oil cooler?? We'll decide on our next project car wrench-fest on June.29th what to do here?
Meanwhile, I'm planning to order up next week the MegaSquirt system, custom wiring harness, wide-band O2 sensor, MSD components, plug wire-set, etc., as I'm hopeful that installation step will be happening sometime in July.
A week from tomorrow, we plan to put all the ancillary engine parts back on the engine, e.g., alternator, power steering pump, A/C condenser, fuel rail, injectors, intake, radiator, fresh hoses, etc, etc. Then go to work on the turbo system install to the extent possible, contingent on decision on oil cooler(s) location.
That's it for now... slow but sure
-RoyW
Posted: Jun 14, 2013 11:44 PM
by Kyle in NO
No reason to give up A/C, I never did.
Posted: Jun 15, 2013 4:14 PM
by riddler
can't argue, but judging by the shape of that exhaust manifold, seems that the gas flow sucks and there must be a long laaaaag, till it starts to spin like it should
correct me if I am wrong
Posted: Jun 15, 2013 5:45 PM
Such a nice comment about a proven system.
Posted: Jun 15, 2013 10:47 PM
by Kyle in NO
riddler wrote:can't argue, but judging by the shape of that exhaust manifold, seems that the gas flow sucks and there must be a long laaaaag, till it starts to spin like it should
You are completely wrong. This system begins to build boost as soon as 2300rpm, and comes on hard before 3000. There is very little lag.
Posted: Jun 15, 2013 11:08 PM
by RoyW
Kyle in NO wrote:No reason to give up A/C, I never did.
I agree Kyle (and, I'd love to keep the A/C), we just need to find a place for the heat exchanger(s) and haven't been able to so far. But, I think today we figured it out. Just need a single long thin (height-wise) one and then make some brackets to secure it, etc. We'll see what units are available thru Todd and see if it will work.
-RoyW
Posted: Jun 15, 2013 11:28 PM
by Kyle in NO
Posted: Jun 16, 2013 6:37 PM
by riddler
wkohler wrote:Such a nice comment about a proven system.
on this side of the pond there are no such systems installed or tested, we mostly build manifolds of this sort to get the best flow and boost at lowest possible rpm
so sorry my bad
Posted: Jun 18, 2013 8:35 PM
by Mab1957
riddler wrote:wkohler wrote:Such a nice comment about a proven system.
so sorry my bad
Sexy
Posted: Jun 30, 2013 10:58 PM
by RoyW
Made some good progress on the project car this past Saturday thanks to my "crew". Accomplishments were as follows:
- buttoned up the upgraded rear brake set-up with fresh pads
- put new acorn nuts/washers on valve cover
- installed some new manifold studs/nuts
- installed fresh fuel lines in engine bay area
- installed new water pump hose
- installed power steering pump
- installed rebuilt alternator
- installed new distributor, cap & rotor
- installed A/C compressor
- installed fuel rail and new TCD turbo kit injectors
- installed intake manifold
- installed new e34 damper, sensor, & bracket
- installed new belts
- removed hard A/C lines and replaced them with flex hose lines from TCD turbo kit
- test-fit some turbo kit parts
Won't get back at it for a few weeks, as the "crew" and my schedule are Summertime loaded with other weekend activities. Still planning to have things ready with TCD Stage 2 turbo kit fully installed, along with Megasquirt system and custom wiring harness by end August. Scheduled car for body, paint and glass work at VSR in Sept... hope we make it
Here are some pics from this past weekend's work.
-RoyW
Posted: Jul 01, 2013 11:04 PM
by Ted in T.O.
Lookin Purdy GOOOOD Roy.
Posted: Jul 27, 2013 7:27 PM
by RoyW
We did some more work on the 535i Project car today, as I had received the custom wiring harness from Peter Florance earlier in the week (the MegaSquirt box and a few other associated parts from him will be here next week), and because my good friend and BMW mechanic, Steve, was available, and Todd from TCD was going to stop by to provide a little consultation on the turbo kit install
Which he did, in the early afternoon, along with John Sweeney
Today's progress included:
- installed the new plug wire set
- installed an MSD coil
- installed the red fan (with new fan clutch)
- installed the new radiator, hoses, and shroud
- installed throttle body and gasket
- installed and connected-up much of the wiring harness
- mocked up parts of the turbo kit (to determine fitment, potential changes in installation and/or parts we may want, and how it all is to go together)
- figured out possible places in engine bay to put the MSD ignition box, and other turbo kit parts (talked about relocating the battery to the trunk to make more room and redistribute weight)
- took measurements for custom single heat exchanger that Todd will have fabricated (will be mounted just below the A/C radiator/fan, where oil cooler is on M5/S38)
- gathered info and asked lots of questions of Todd and Sweeney regarding the Stage 2 turbo kit, its install, and "options"
- on a side note, we replaced the faulty brake switch on the Alpina B7 (now works fine). Also, tested A/C system for leaks (none found) and charged the A/C system, which was very low. Found fan doesn't work and compressor not kicking on when A/C button is pushed (it lights up). Tested compressor and determine it can be forced to function.... so, more work to do to sort out A/C problem(s)!
It looks like a couple more work sessions are needed on the Project car (and, of course, more parts!) and we should have things ready to go for "start your engine!" I'm figuring late September based on everyone's schedule. Peter is putting a "base tune" on the Megasquirt system (box), leaving final tune for much later (after paint and the rest of the car is back together in Spring '14). I've resigned myself to moving the paint work; glass, euro bumpers, & valance install, etc., etc., at VSR, back into Oct/Nov time-frame (from Sept), with next Spring now planned for the coming out party... this will give me the Winter to work on all the other little build details once the car is back from VSR, e.g., installation of trim, lights, interior, sound system, etc.
Again, my thanks to my friend Steve for all his work in leading this build thus far, and thanks to Todd for driving up from NY... I'm learning alot!
Here are a some pictures of today's results.
-RoyW
