E28 M5 swap restoration
savannah996
Post by savannah996 »
Jbort im planing to do all the same stuff. Dont think Ill want to do that dam headliner though. Unless someone wants to come help.
JBort
Post by JBort »
savannah996 wrote:I was kidding about the brakes.
If I didnt know the difference I shouldnt be doing this.
Thanks guys for pointing out all the differences.
How do I tell if the M has lighted sun visors?
I see a mirror on the back but the car does not have power.
The illuminated vanity mirrors were an option:
The standard visors did not have the sliding mirror covers, or the plastic perimeter lighting (working or not).
savannah996 wrote: Jbort im planing to do all the same stuff. Dont think Ill want to do that dam headliner though. Unless someone wants to come help.
In this car and another I've seen, the beige headliner was masked and painted black when the interior was out. You wouldn't know it unless you looked really hard! ;)
Any questions, or if you need pics, just pm me. I'll lend a helping hand from California.
savannah996
Ok thanks, those are the sun visors I have, which are not in the 528e. Any other electrical stuff on the interior?
Not including the battery, I know I have to r and r the box in the trunk. Also im not swapping the self leveling suspension.
JBort
Post by JBort »
savannah996 wrote:Ok thanks, those are the sun visors I have, which are not in the 528e. Any other electrical stuff on the interior?
Map light rearview mirror?
Heated seats?
savannah996
I will have to check that light/heaters issue tomorrow. Man thanks for the help. I havent paid much attention to the interior so far. Planning to take care of interior after the M is running.
Started digging into the head yesterday. This thing was the cleanest vintage engine ive ever seen!
JBort
Post by JBort »
Nice!
Check valve clearance?
:banana:
savannah996
Wednesday. Im really hoping the chain guides are ok. They are not cheap.
m535is
Post by m535is »
Replace them while the motor is out. So much easier and they won't get any cheaper.
savannah996
Anyone upgrade injectors? Seems low impedance injectors are not common around the junkyard. Switching to 4 pintle would be nice. Worked great in my 535i.(high ohms)
m535is
Post by m535is »
No need, they last a long time and you can get a rebuilt set for cheap from fiveomotorsports.com.
savannah996
Well it does look like I have heated seats and map lights. I will take care of swapping them when the M is up and running.
I got the head off today and luckily no surprises.
Valve clearance is exactly in spec.
savannah996
Rebuilding this head is taking forever. Would you believe I actually need to buy a new socket? After almost 40 years there is yet another to buy, a 17mm deep thin wall spark plug socket.
Might have the head back together this weekend, planning to have engine ready to drop in for friday morning. Start up Dec 1st?
fjfar80
Post by fjfar80 »
That looks really nice...keep the thread current; I think we all enjoy watching these projects come together.
- Mark
JBort
Post by JBort »
savannah996 wrote: a 17mm deep thin wall spark plug socket.
BMW S38 spark plug socket (from PP)
Magnetic holder inside.
savannah996
Yeah I found out last night its not 17mm. What size is it? (before I grind down my 18mm today)
HealeyBN7
Post by HealeyBN7 »
11/16". The threads are metric, but the flats are SAE.
http://www.turnermotorsport.com/p-1213- ... gines.aspx
Dean
savannah996
Wow $70! What a rip off!
I bought a $10.99 socket set (deep, metric, anodized) 10-18mm I think, from harbor freight. I ground down (10 minutes) the 18mm socket on a bench grinder. It fits perfectly. Lifetime warranty on the ones I didnt grind.
Booyah!
savannah996
Took a break from the head to clear out the trunk of the donor M5. I need to put all my scrap metal and junk in there but dont want to have to pull it back out.
This dam battery box was more trouble than it was worth! Jeez BMW did you have to make it a stressed part of the frame!!!
savannah996
(After 3 hours of porting/polishing), I thought I was just going to remove to exhaust port carbon. ................
m535is
Post by m535is »
Don't forget that the support beam to the right of the battery box is also M5 specific. So you can either cut out and replace or you can notch the one in the other car.
savannah996
m535is wrote:Don't forget that the support beam to the right of the battery box is also M5 specific. So you can either cut out and replace or you can notch the one in the other car.
Can you please be more specific? I fitted the box this morning and didnt see a problem.
Pavel
Post by Pavel »
:popcorn: :beer:
m535is
Post by m535is »
The M5 trunk panels will not fit properly unless you cut back or change the panel to the right of the box. Look at your two pictures and you can see the difference in the pieces. This is what I had to do to make it work in my car. Other thing you can do it measure where the box was welded onto the floor by some fixed points like the fuel tank access hole and then you will also see the box is currently sitting too far towards the middle of the trunk. The box needs to go about 1/2 to 3/4 of an inch to the right.
Oh yeah and while you are at it, you need also the tabs under the trunk seal area that help to hold the side panels of the trunk carpeting in place. Without those the carpeting does not hold properly.
savannah996
Head finished up, headers, fuel rail painted, Throttle bodies cleaned.
savannah996
savannah996
What's the RA on that head?
bobby in Derby City
Post by bobby in Derby City »
wkohler wrote:What's the RA on that head?
your on a mission today, eh playa :pimp:?? :up: :cool:
savannah996
Starting to look like a real engine=
:up:
