Jelmer's 538iS *sold*
tsobrado
Re: Jelmer's 538iS *digital oil temp and pressure*
Post by tsobrado »
Very nice.
I did a quick online search and this was the only reference I was able to find:
http://www.claasi.de/tip001400.php
kronus
Post by kronus »
this is the website I found: http://www.claasi.de/tip001400.php (from this thread: http://www.bimmerforums.com/forum/showt ... sure-gauge)
I'm interested in getting one of these setups, about to send the guy an email. Will find out if he's interested in doing a GB.
also, really nice E28, OP. I'm beginning to like spoilerless trunks more and more.
Jelmer538i
Post by Jelmer538i »
You guys should ask if he can make them in Fahrenheit and PSI.
kronus
Post by kronus »
i did, and no :/
NAH
Post by NAH »
tsobrado wrote:Very nice.
Thanks! :D
That gauge set is brilliant.
I've been wanting and Audrino project for a long time. I think I just found one.
Looking forward to installing mine. Please keep us updated on the process.
Jelmer538i
The gauges are installed! I was a very easy job.
The cluster before:
Opened it up and placed the new oil pressure and temperature face plate:
Drilled some holes to accept the screwes that came with the kit to keep the digi gauge in place. It has to press against the cluster otherwise you don't see the numbers clear:
Looks good!
After that you have to cut out some plastic from the backingplate. I used a dremel with a cutting wheel for this job.
And after this reassamble the cluster and you have this! BTW, this particular M5 tacho is from the famous E28 M5 racer that was at 5erFest 2007 where I bought it
Owndapwn
Post by Owndapwn »
Has anyone had luck getting these in the states?
tsobrado
Post by tsobrado »
Kronus put together a group buy. The details are in the for sale section.
Thanks Kronus.
What great timing. Right after I sent my check.
kronus
Post by kronus »
to be fair, i did say that I'm contacting the guy about a group buy..
anyway i hope the GB works out! Roland said that he's going to be in CA in May and can bring a bunch of these over.
I made the deal on mine before the link was ever posted to the thread so it doesn't really matter.
Owndapwn
Post by Owndapwn »
Might be in on that. I'm tired of seeing prndl on my 5spd, and I really wish I knew my oil pressure, and I'm willing to learn bar if it looks that OEM.
Jelmer538i
Is this tread for the group buy? :| :laugh:
Hey, I just noticed you're not using a Euro fuel gauge! ;)
Jelmer538i
No, my cluster is a complete mix of parts!
* Alpina housing (with the very good looking grey inside!)
* Alpina 300km/h speedo (and oem orange needle)
* M5 rev counter
* US temp and fuel gauge
* US face plate for warning lights
I ordered some stuff for our Dodge Cummins at WhitefaceGauges.com (stock looking "km/h" gauge faces, no white shit here offcourse!) and also ordered orange gauge needle paint so when that arrived I will paint all the needles of my cluster the same orange color.
Jelmer538i
Installed my 3.62 210 diff yesterday with fresh LSD clutches! What a blast to drive now! It feels good to drive it again after winter and with the way to long 3.07 diff.
Did some donuts to check if the LSD works and it did! :rofl:
Jelmer538i
And working! They really look awesome!
Jelmer538i
Well, I'm not that happy anymore.....it reads wrong if compared to my analog VDO gauge. The VDO reads 80 degrees and the digi gauge reads 100 already while I'm just cruising around town. Also, the pressure doesn't work, it reads 0.3 bar with a shut down engine and reads 8 bar when idling cold. When you start driving it gets down pretty fast and even reads 0 bar when idling warm but my light doesn't come on and i know for sure that my oil pressure is fine. I used all brand new senders.
I hope is isn't a piece of cheap that just looks good. It also made my blower motor keep working when I turn the ignition of but keep my headlights on...... :evil:
^^^ One of two things?
- faulty/defective board, or
- people are spending money to be beta testers.
Jelmer538i
I've contacted Roland and he said that a VDO temperature sensor reads to much, so I need to use the OE BMW sensor. For the pressure, it uses a 0-10 bar VDO sensor. I don't know which one I have (had it laying around for a couple of years) but I bet it is the 0-5 bar one.
But what about the lights and such staying on?
ronin
Post by ronin »
Did he give you the part number for the correct OE BMW sensor?
Thanks,
Eric
Jelmer538i
I have a new "project"for the 538iS, a standalone engine managment. It is a KDFI from Germany and MSII based. It is a PNP system but I will ad a wide band lambda sensor so it can run in closed loop and I want to run a MAP sensor for regular driving and Alpha-N for WOT. The KDFI already has a MAP sensor build in and also a lambda controller build in.
sansibar
Post by sansibar »
The oiltemp/pressure cluster from Roland uses the OEM temp. sender form euro M3 E30, and it works fine, have the same cluster in for a few years now. Ordered about ten units for the french E28 Forum and all work fine, for the pressure sender use the VDO 0-10 bar otherwise you get absolutely wrong data. There's a combi sender which also gives the signal for the 0.5 bar warning bulb in the BMW cluster.
rob from Luxembourg
kmark1
Post by kmark1 »
off topic but those wheels look fantastic on there
Jelmer538i
I've fitted a E32 V12 starter to my S38B38 this weekend to have a more powerfull starter. It fitted without problems so it is a nice upgrade for high compression engines in cold weather.
It is tilted a bit more upright but it cleared the S38 intake so it shoudnt give problems in a M30 either.
I also upgraded to bigger/thicker battery cables and a 100amp/h battery. Next step is a 140a alternator to keep this big basterd charged!
Owndapwn
Post by Owndapwn »
Jelmer538i wrote:I've fitted a E32 V12 starter to my S38B38 this weekend to have a more powerfull starter.
Based on the title, I thought you were starting on a V12 swap.
I guess, technically, you are. Just taking things a bit more literally.
