Deus Ex Machina
mremingtonwilson
Post by mremingtonwilson »
Finally the plenum is finished. Started with a very thorough cleaning and used a little media blasting to get the paint off. Then I used a Dremel to sand off all the casting burrs, media pits, and smooth out the scratches and dings. Applied 2 coats of primer in total, each wet sanded up to 600 grit, and about 3 coats of color, the first two being wet sanded as well. The whole process took about 4 weeks. All of it was painted in my garage, unconditioned, in Portland, where the humidity was in excess of 80%, and I was spraying from can. The final product will hang here for a week or more to fully cure.
The color is as close to the Himmel Blau of the Roundel as I could match for $14. ;)
[/img]
marc79euro645
Post by marc79euro645 »
Beautiful!
Eta power
Post by Eta power »
Fucking amazing!
mremingtonwilson
Engine is back. Now working on reassembly. Haven't decided if I should break it in NA and then turbo or turbo and then break in. Thoughts? Specs on the sheet.
mremingtonwilson
Priceline sale on the stuff in the garage. Good thru Sunday night.
Happy weekend!
http://www.mye28.com/viewtopic.php?p=1109371#1109371
fastcrs
Post by fastcrs »
You weren't kidding when you said expen$$$ive...those ITB's look like pieces of art...this thing is going to MOVE...got the ss lines today, thanks for the quick delivery, best of luck with the build...
