How to: e28 Suspension Install
MLastovo
Post by MLastovo »
BuzzBomb wrote:
MLastovo wrote:
Frybrid 524td wrote:
MLastovo wrote:
Frybrid 524td wrote:They'll start to sag over time.
Agreed. Please note that all springs under load will sag over time.
Do you have any historical data on BAS spring performance?
If so, do you have same/similar data to compare to other brands and/or stock springs?
r/
D.
Of course all springs under load will sag with time but based on anecdotal evidence shared numerous times here on the forum, BavAuto springs tend to sag prematurely.
Any chance you have the posts indexed?
I've been around since before Roachfly and don't recall ever reading any posts but I may have missed one.
r/
D.
:duel:
Antknee,
Not at all. I am simply attempting to find the info that validates the statement.
Without data the claim is without merit.
r/
D.
pstl_pete
Post by pstl_pete »
From what I recall, the front Bilsteins have built in bump stops, the rears do not. I remember stopping the install to check into this since I wasn't sure whether I should cut the bump stops or use them.
I double checked the front and rear springs and the writing is right side up so they are properly installed.
I too am a bit skeptical on sagging, heard lots of stories about sagging springs yet have never encountered or seen the issue.
Frybrid 524td
Post by Frybrid 524td »
MLastovo wrote:
BuzzBomb wrote:
MLastovo wrote:Agreed. Please note that all springs under load will sag over time.
r/
D.
r/
D.
:duel:
Antknee,
r/
D.
As I mentioned, I based my statement on the anecdotal evidence offered by other members here. Without spending too much time, a quick search brought up numerous threads in which the sagging issued was mentioned.
http://www.mye28.com/viewtopic.php?t=33866
Shawn D. notes the Bav Auto sagging issue.
http://www.mye28.com/viewtopic.php?t=35905
See C.J.'s comments.
If you need more data, D., PM me or just conduct a search. This is getting long-winded and off topic for the thread. It's an Internet forum, the majority of things said here are not backed up with data. People share their first-hand experience for the benefit of others. Since numerous people have found BavAuto springs to sag prematurely, I thought it was worth mentioning to the OP. I do not have Bav Auto springs due to the warnings of others here. My spring experience lies with OE and Dinan.
MLastovo
Post by MLastovo »
MLastovo wrote:
BuzzBomb wrote:
MLastovo wrote:
Frybrid 524td wrote:Of course all springs under load will sag with time but based on anecdotal evidence shared numerous times here on the forum, BavAuto springs tend to sag prematurely.
r/
D.
:duel:
Antknee,
r/
D.
Thanks for the links and I concur on the spin off.
As a side note I'm running BAS/Billie Sports since 2002 (installed in April in prep for the first 5er Fest) on my DD and have about 100k miles on 'em. No track days just SoCal driving primarily on San Diego's NASTY streets. No regrets.
I have driven many miles (low hundreds) on several occasions on both Dinan and Eibachs and found the Dinan setup the better of those two. I picked the BAS's for the drop and the soft, yet progressive, ride/stance.
r/
D.
My BAS springs are fine and I have had them on now almost 3 months.
A little soft in the back for me but otherwise i like em enough for what I do. I plan to install e90 drophats at some point.
miamibeamer
Thanks
Post by miamibeamer »
Thanks for taking the time to document the install. I'm planning to tackle on the same project before end of year.
shagrath wrote:My BAS springs are fine and I have had them on now almost 3 months.
A little soft as in they bottom out or jus very comfy?
BuzzBomb
Post by BuzzBomb »
Also, just as an FYI, the photo of the rears during assembly show the bump/dust boot put together backwards. The foam bumper is an extension of the boot, the convex cut facing up. It's not meant to disappear inside the boot itself.
Sorry I did not respond to this. Never saw it.
Both. Very comfy in the back, but with three kids and a trunk full of groceries she will bottom out a little on extreme bumps.
dude8383
Re: How to: e28 Suspension Install
Post by dude8383 »
BuzzBomb wrote: Correct procedures are:
1 No, pliers aren't used for that. Use the right tool.
Where does one find said "right tool"
Bilstein never includes it with their shocks
EtaMonkey
Post by EtaMonkey »
I too am curious about what the right tool is called and where I can get one.
I just ordered the same stuff from Bavauto and am hoping to tackle the job in the next couple of weeks.
Might save for some brakes/rotors while I'm waiting 1-2 weeks for some parts to come in.
Blue Shadow
Post by Blue Shadow »
I wonder if those pliers are calibrate to put 103 pound-feet of torque on the Bilstein strut retaining nut as specified on the Bilstein tool for the task?
The rear shock mount nuts are the reason the gearwrench tools were developed. No patience needed, just plop the 13 on there and zing those things off and on.
Blue Shadow wrote:The rear shock mount nuts are the reason the gearwrench tools were developed. No patience needed, just plop the 13 on there and zing those things off and on.
I no dats rite. :lol:
John in VA
Post by John in VA »
EtaMonkey wrote:I just ordered the same stuff from Bavauto and am hoping to tackle the job in the next couple of weeks.
Are people still buying from them? I found you could always buy cheaper. You wouldn't need to save up if you were shopping with BluntTech or AutohausAZ. I understand Bav will match prices, so I hope you are taking advantage of this.
Might have to try that. I was planning on dropping a socket on an extension through the rear shelf, since I already have it off, but...
BTW: Nice writeup, pstl_pete! :up:
BuzzBomb
Post by BuzzBomb »
dude8383 wrote: Where does one find said "right tool"
Call Bilstein. Ask nicely(like I did) and they'll send you one.
EtaMonkey
Post by EtaMonkey »
Guess my email filtered out the replies to this thread? I'll have to try calling Bilstein, Bavauto doesn't have the tool and said to use a pipe wrench with something soft to protect the nut. I asked about torquing to specific values and they said - nope, can't do it.
I am actually in the process of trying the rear suspension now. I've removed the 22mm bolt from the bottom and the (3) 13mm from the towers. The shock/spring assembly isn't budging. I've tried tapping pushing and prying - nothing. Advice?
I've generously applied rust blaster and am waiting for something to happen. Perhaps the last person didnt put a gasket i between the top and the tower?
BFH.
EtaMonkey
Post by EtaMonkey »
A properly administered side kick released it from the trailing arm. Tae Kwon Do paying off 28 years later :banana:
Busted loose many a stuck wheel using that technology.
Metal parts usually get something equally hard, ie. BFH.
SPF2006
Post by SPF2006 »
Very helpful thread -- also attempting this job now (with the usual problems) and the photo documentation is a big assist.
EtaMonkey wrote:I am actually in the process of trying the rear suspension now. I've removed the 22mm bolt from the bottom and the (3) 13mm from the towers. The shock/spring assembly isn't budging. I've tried tapping pushing and prying - nothing. Advice?
e24mpwr
Post by e24mpwr »
Getting ready to do this on the M635. Going Bilstein Sport all around. Did they indicate how to torque? I have 1/2" and 3/8" torque wrenches, but don't see how is user them with that collar...
BuzzBomb
Post by BuzzBomb »
The driver of the torque wrench fits into the square hole under thumb in that picture.
e24mpwr
Post by e24mpwr »
BuzzBomb wrote:The driver of the torque wrench fits into the square hole under thumb in that picture.
Color me embarrassed. :oops: (and thanks!)
Looks like 3/8"?
BuzzBomb
Post by BuzzBomb »
e24mpwr wrote: Looks like 3/8"?
There's one way to find out... ;)
e24mpwr
Post by e24mpwr »
Got my ring in the mail today - that thing is sturdier (and bigger) than I expected.
LarryM
Post by LarryM »
I'm still a bit confused on the external bump stops and protective boots, and when they're needed. Someone previously said Bilsteins have internal bump stops, but it seems to me like something's missing.
I just received all my M-Tech suspension bits ("short Red" springs, factory-revalved Bilsteins, etc.) but didn't order items # 11 and #12 for the rear shocks. Do I need these?
http://www.realoem.com/bmw/showparts.do ... g=33&fg=45
e24mpwr
Post by e24mpwr »
e24mpwr wrote:Got my ring in the mail today - that thing is sturdier (and bigger) than I expected.
As a follow-up, the ring didn't fit the old shocks, but did fit the new ones. It is 1/2", and kind of a pain to use...
e24mpwr
Post by e24mpwr »
LarryM wrote:I'm still a bit confused on the external bump stops and protective boots, and when they're needed. Someone previously said Bilsteins have internal bump stops, but it seems to me like something's missing.
I needed them in the back for my Bilstein Sport set in the rear only (11 & 12 in that diagram). The set that was already in my M635 were yellow and didn't have bump stops in the front and the new Sports in the front don't need them.
Chimi-Changa
Post by Chimi-Changa »
Anyone know where I can source a gland nut tool? ( 08/6)
Checked with Bilstein and forum member listed above- no luck yet....
