Euro 535i LS Turbo Build Thread - 7/10/19 Dyno update
Jeremy wrote:
T_C_D wrote:I should be able to adjust fuel pressure prior to running the car by looking at the fuel pressure sensor transducer prior to start as well.
You're using an adjustable regulator instead of a plain traditional one?
Correct.
Getting into it.
DangerWillRbnsn
Post by DangerWillRbnsn »
I continue to be impressed with your work, Todd. Very nice!
T_C_D wrote:Getting into it.
Yea baby....lots of shrink tube is your friend.
Main connector mostly installed. Starting on the MS3X connector tomorrow. Start up within a week? :shock:
Main harness finished, MS3X harness partially installed. Communicated with ecu and datalogged while turning over the engine. Discovered I wired the TPS incorrectly. Will fix that tomorrow and start on the ignition coil wiring.
Was 28F in the garage this morning.
Good & Tight
Post by Good & Tight »
Looks almost like a factory option, looks great Todd.
scarey013
Post by scarey013 »
Yes, good work. The attention to detail is refreshing.
Eddie in TO
Post by Eddie in TO »
vid request of 1st tire shredding moment.... :rofl:
You are sooo going to mess some people up at the dragstrip.
ldsbeaker wrote:You are sooo going to mess some people up at the dragstrip.
Until he is known which should take about two runs. Then you will see the Corvette pukes wave cars past them as to not line up with Todd.
Corvette - keeping the legend alive.
My 2nd prediction.
The limits of the e28/e20 rear diff will be pushed into unseen limits.
By "dragstrip", I meant the AHEM, stoplight drags.
The dragstip is a personal challenge for me. Of course I am always interested in how I measure up but there are now enemies at the dragstrip. I am keenly interested in fast street cars of all makes and models.
Finished the coil wiring today. Only 16 wires left! Will it start tomorrow?
Shadow
Post by Shadow »
There was an old jaguar at the 1/8 last time that had
a turbo ls1 in it. License plate said Jeeves. lol
Total sleeper.
Finished the wiring but no dice. Battery is dead and even with a charger the engine/starter draws too many amps. Voltage drops to 10.5 or lower. May not be enough to effectively fire the coils. Did verify that I have spark and fuel though.
So, buying a new battery Sunday and installing a fuel pressure gauge before trying again.
That sucks to be thwarted by a dead battery. I await good news that it fires on the first try.
Brad D. wrote:That sucks to be thwarted by a dead battery. I await good news that it fires on the first try.
It's not a big deal. Blizzard conditions outside. Won't drive this car in the salt anyway. It just needs to be ready by mid March.
Brad D. wrote:I await good news that it fires on the first try.
That never happens...EVER!
If you see a show where they claim it does....they have started it multiple times before hitting record.
I do wish I was there Todd when you do get it running.
RossDinan6
Post by RossDinan6 »
I beg to differ. While you were cobbling together a bunch of mismatched parts on your M car, I installed stand alone on the boosted E24. It lit right off and idled.
Sorry for your defective battery Todd.
Ross
scarey013
Post by scarey013 »
Pull one out of the DD. You're going to let a little battery problem hold you back? ;)
winfred
Post by winfred »
maybe its a e24 thing, my frankeninjection system worked on the first try, only bug was a starter relay that barfed right when it was time to try but a jumper wire got past that
for those that don't know its a red label 413 (3.3.1) from a m50tu on a modified 93-95 525 harness, completely hand built tone system for cam sensor and m30b35 balancer with the teeth shuffled around all installed on a m88/3
RossDinan6 wrote:I beg to differ. While you were cobbling together a bunch of mismatched parts on your M car, I installed stand alone on the boosted E24. It lit right off and idled.
Ross
Installed a fuel pressure gauge which indicated no fuel pressure. Disconnected the return line at the regulator and switch the fuel pump on. Sure enough fuel poured out of the return line. :laugh:
Smashed my thumb installing the new battery earlier so decided to call it a day. Will swap the lines at the fuel pump tomorrow. I think it might actually start.
Oh, I know this all too well. But you have to shoot for something!
pleasefixitup
Post by pleasefixitup »
hate car injuries. I hate when you smash your hands or face and it hurts so much but yelling doesn't help...UGHHHHHH
first start! hope it fires right up! first starts make me so nervous.
pleasefixitup wrote:first start! hope it fires right up! first starts make me so nervous.
One big thing Todd has going for him is the sensor check before start attempt and not having to stab a distributor trying to get the right the first time.
Having pulled my engine several times now to fix leaks (still absolutely leak free BTW) and install the distro....this last time I got it right the first time and it started right up.
Duke wrote:
One big thing Todd has going for him is that he is wicked smart and has Sweeney and Peter Florance on Team TCD.
Fixed. :rofl:
It started! Going to tidy up some wiring and get a video.
