Page 8 of 19
Posted: Jan 22, 2010 9:19 AM
by T_C_D
Good & Tight wrote:Raced the Viper last night, 06GTS with a 200 shot.
I turned the boost up to 22psi for this race, 80-160.
Viper beeped it off, I was in 4th so from the start he jumped out a car which I would expect from a 200 shot of nitrous, by the end of 4th I had pulled a nose then shifting into 5th he shifted also and pulled a car on me, 1/2 way through 5th I started pulling on him but then he hit the brakes.
He said we were at 160 when he hit the brakes, so I lost by a car.
Viper owner says it dynoed 650hp 780tq, car was very fast.
You win some you lose some, I lost this time.
I would imagine the aerodynamics of your car at those speeds isn't favorable.
Posted: Jan 22, 2010 9:21 AM
by Good & Tight
T_C_D wrote:Good & Tight wrote:Raced the Viper last night, 06GTS with a 200 shot.
I know it's like a refrigerator
Posted: Jan 22, 2010 11:04 AM
by Lurker27
Sounds like it is time for 22+psi. Amazing car, G&T
Posted: Jan 22, 2010 2:20 PM
by Scottinva
I love your car becomes it proves, you don't have to everything perfect and be so anal about a build. You do it right, you fix what needs to be fixed and just get it done.
Posted: Jan 22, 2010 5:52 PM
by ldsbeaker
Good & Tight wrote:You win some you lose some, I lost this time.
I would have to say that you're losing to some pretty heady competition. These aren't your run of the mill cars that are (barely) beating you...
Combining the best of both the E28 and E30, that's what I dig the most.
Posted: Jan 23, 2010 12:06 PM
by Good & Tight
Just came back from the dyno, I have some spark blow out at 21psi so need to regap the plugs down from 24 to 20 and probably get a better coil pack and new wires. The junk yard parts can get you only so far:stickoutt
I raced an 06 Viper GTS with a 200 shot the other night from 80-160 on this exact tune and lost by a car.
Tires just fit and rub just a touch when it's full throttle. Thanks Jordan:buttrock
Who would ever think a single cam piece of shit would be this much fun:lol
Posted: Jan 23, 2010 12:15 PM
by e30-m30_kid89
Fawking awesome! woulda loved to see you hit that 500whp mark but meh close enough..
Is your heart set on the HX40 or will you be considering a future turbulator?
Posted: Jan 23, 2010 12:34 PM
by M. Holtmeier
Damn!
Can you please give us a rundown on the longblock again? I can't remember what crank/block/head/cam you ended up with.
Posted: Jan 23, 2010 12:47 PM
by Canuck YYC
Holy shit! Hahahaha...that's awesome. Nicely done mate.
Posted: Jan 23, 2010 1:09 PM
by Good & Tight
e30-m30_kid89 wrote:Fawking awesome! woulda loved to see you hit that 500whp mark but meh close enough..
Once I fix the spark blowout 500whp should be doable, plus I think it needs some more boost
The HX40 might be at it's limit, the inducer wheel is only 59mm I am looking into upgrading to a bigger wheel.
grsmonkey wrote:Damn!
Stock 86 B34 bottom end, unknown mileage, 1980 M90 head with an old Schrick 280/284 cam, double springs, Cometic HG, ARP's.
Canuck YYC wrote:Holy shit! Hahahaha...that's awesome. Nicely done mate.
Thanks, it deff puts a smile on my face
Posted: Jan 23, 2010 5:48 PM
by babisbabou
Serious power here
That's good
Posted: Jan 23, 2010 6:56 PM
by T_C_D
Awesome. I look forward to you getting it sorted out.
Todd
Posted: Jan 23, 2010 8:42 PM
by George
Otis, to help convert the speed run on the dyno jet to rpm can you give us some specs?
Gear
Diff
Tire Size
I'd really like to know when that thing spools.
Posted: Jan 23, 2010 8:52 PM
by Scottinva
thesixerkid wrote:Otis, to help convert the speed run on the dyno jet to rpm can you give us some specs?
Gear
Diff
Tire Size
I was just thinking this too. I don't understand why you would want a dyno chart for MPH. I hate it, I want to know when this sucker spools, not at what MPH.
Posted: Jan 23, 2010 9:02 PM
by Shadow
Looks like 5,252rpms at about 105mph.
Was this in 4th gear?
Posted: Jan 23, 2010 10:13 PM
by Good & Tight
Gear
Diff
Tire Size
4th gear
3.73
235/60/15
It spools around 3500rpm.
I think the HX40 might be maxed out, the inducer wheel is 59mm.
Dyno vid from today. tires spun on the first pull.
http://www.youtube.com/watch?v=AyER6AlIDdg
Posted: Jan 24, 2010 2:40 AM
by shocka
Unbelivable work Otis, ive read some your posts regarding m10 builds. Keep up the chain drive love. M10/30 FTW!!!!
Posted: Feb 06, 2010 8:01 PM
by Good & Tight
Here's a quick vid, sorry about the poor visibility.
08 Z51 supercharged with 700hp. I was running 18psi not 22 like the vid says, having boost problems. Lost by a car.
http://www.youtube.com/watch?v=x8tmJu_H ... r_embedded
Posted: Feb 07, 2010 2:30 AM
by iXer
It would be fun to have your ECU mapped with the car strapped to a hub dyno, or a very grip-friendly roller. I think you could use more timing at 5000-6000 rpm where you spend a lot of the time in a run like that. As long as the dyno agrees, do it.
Just be careful with timing at 3500-4500 rpm, could be spot-on as it is.
You could use a larger turbo, that's for sure.
Posted: Feb 08, 2010 11:00 PM
by Good & Tight
Here's a 4th gear data log pull.
Posted: Feb 13, 2010 9:16 PM
by Good & Tight
Posted: Feb 13, 2010 9:40 PM
by Scottinva
Posted: Feb 14, 2010 3:40 AM
by Jay Bee
that size is great.
64mm in 73 out and a 19 housing,
Go for the 600+, your definately motivating me to get back in the cold under the car
Guess ixer is happy to see this
Posted: Mar 14, 2010 10:52 PM
by Good & Tight
Jay Bee wrote:that size is great.
Preparing for the HX55.
I have been having some boost issues and started thinking there is some kind of restriction with my current exhaust setup. 4" down pipe then into 3" which has worked well but just wanted to be sure.
Picked up a 10' length and two 45's, aluminized steel, big difference between the two for sure. Kind of felt silly while putting it in . even my wife was like "wtf are you doing"
Here's it is all finished, ground clearance is good even over speed bumps.
Deff spools up a lot faster and stronger pull up top, traction really owns my ass now. 40 roll no way 60 roll is still a little squirrely.
Oh and it's deff louder than before.:lol
Next on the list is replace the BOV.
Posted: Mar 14, 2010 10:57 PM
by M. Holtmeier
Holy mother!
You still getting along with e85?
Posted: Mar 14, 2010 11:07 PM
by T_C_D
All straight pipe? Do your neighbors hate you?
Posted: Mar 14, 2010 11:35 PM
by Scottinva
T_C_D wrote:All straight pipe? Do your neighbors hate you?
Seriously. I thought it was ridiculous before.
Posted: Mar 14, 2010 11:54 PM
by Brad D.
Haha, that's awesome.
Posted: Mar 15, 2010 1:27 AM
by shocka
Lets hear it
Posted: Mar 15, 2010 8:48 AM
by Good & Tight
grsmonkey wrote:Holy mother!
Still running E85 and loving it
Yup all straight pipe and
I hate my neighbors.
