scott s
Post by scott s »
3.73 LSD <3
Gelatinous
Post by Gelatinous »
replaced two hard hoses in an attempt to fix my funky idle... no dice. ugh.
TurboChris
Post by TurboChris »
Fixed the non-op aux fan....installed a bung in the exhaust for a wideband and fine tuned the Split second mass air...oh and fixed the headlights (only low or high....now I have both)
Post by slammin_e28 »
slammin_e28 wrote:Nothing.
System77
Post by System77 »
Heater Valve Rebuild Kit
took me about 8 minutes..
yay heat! even though we are having a heatwave right now, Im going to be happy in a few weeks!
ordered from http://www.bimmerspecialist.com
best price I could find in Canada at $58 and they shipped it super fast!
Post by rmiddendorf »
Apparently its monsoon season in Central Ohio. I opened the trunk to see if water was leaking in. It wasn't until I opened the trunk.
:facepalm:
Then I proceeded to get a towel and dry it up and leave another in there to soak up any more moisture that gets in.
I do, however, need to replace my trunk seal with the brand new one also sitting in the trunk. I just need to get the proper glue needed to glue it down... well that and figure out what the proper glue needed actually is... lets try out that search function...
damacus101
Post by damacus101 »
New ignition rotor, cleaned up distributor cap, new plugs, valve adjustment & new cover gasket. Found and corrected a sizable post-AFM vac leak. Another step in the right direction!
Last night... Pulled the driver's door panel off & found that the reason the inside door handle disappeared on my son was because he managed to break both mounting tabs off of the thing.
He said the trim piece came off and he was trying to put it back on and the whole handle disappeared. No idea how he did that. But that was two days ago, and since then he's been lowering the window to get out of the car, and at some point the lift mechanism crunched what was left of the handle. New part on order; under $10, so nbd, but still... How'd he manage to do that?
While we had the door panel off we re-greased the window mechanism; it was dry as a bone.
Wow does it work better now! :shock: :banana:
ilikemybike
Post by ilikemybike »
Instead of wiring in rear fogs to my new euro fog light switch as planned, wired my city lights to the rear fog switch. Now I can have ONLY my city lights on. Before I had them wired into my parking lights.
All of this was done after doing this yesterday to my thumb with my tablesaw.
Found this in the shop after I got back from the ER.
twin55
Post by twin55 »
Yesterday the auxiliary fan stop working and I had no other choice but to changed the fuse box today. I should have done this last year when I first pulled the fuse box from the junk yard. :oops: I was surprised that the air condition was still working.
ilikemybike wrote:Instead of wiring in rear fogs to my new euro fog light switch as planned, wired my city lights to the rear fog switch. Now I can have ONLY my city lights on. Before I had them wired into my parking lights.
:shock: Dude; that's nasty! I'll bet that hurts like anything! :shock:
:puke: (not really, but... Dave beats a hasty exit to find some kitten pictures to help scrub that image out of his brain...)
Xenocide
Post by Xenocide »
ilikemybike wrote:Image
Looks like your manicurist cut that last nail a little too short, you should probably get your nails done somewhere else. ;)
Glad you still have as much of that finger as you do, that was a close call.
euro635gas
Post by euro635gas »
I just lost my appetite. No breakfast for me.
Thanks
Please...
...help...
...me...
...get...
...this...
...thread...
...to...
...page...
EDIT: ...eighty one. Whew. Now I can look at it before breakfast tomorrow. Double whew.
Rolf-Dieter
Post by Rolf-Dieter »
Drove by my daughters house, then peeked into my daughters garage window made sure our babe is safe and sound :)
We are waiting for a third quote to change the 2 front fenders out (somehow the rust took over in the wheel arches).
rmiddendorf wrote:...page...
Hold on there Hoss; that's cheatin'!
gfoto
Post by gfoto »
I am on vacation with my E28....and the left back shock started to squeeeeeeeek....
grey ghost
Post by grey ghost »
Diff mount.
Need to do my subframe bushings. Right rear is clunking.
I did them at 180K. Now that I am pushing 350K, they are "done" again.
I think I did Meyle HDs last time but I'm not sure, I'll will be using them this time for sure.
grey ghost
Mounted sub box in trunk and replaced OBC light bar.
May have found a wrecked m30b35 donor for it... Anybody need e34 doors, auto trans (4HP22) & interior bits? :D :D
davintosh wrote:May have found a wrecked m30b35 donor for it...
:) :up:
Gelatinous
snapped a head bolt on the weekend :(
Rolf-Dieter
Located 2 new front fenders .... started the project on the e28 this week ... more photos to follow ...
