External links now open in a new browser tab - turn this off in your UCP - Read more
here .
Posts: 7733 Joined: May 27, 2009 11:42 AM
Post
by T_C_D » Sep 05, 2012 9:32 AM
Few more pictures of requirements to install the engine without compromise. It sits very low.
Lowered sway bar mount.
Repositioned control arm reinforcement bar. It had to move forward to clear the bell housing.
And one of the super simple charge piping. It consists of a silicon 45 off of the turbo to this aluminum elbow to another 45 silicone connector to the intercooler. Total length about 2 feet.
Eddie in TO
Posts: 1007 Joined: Feb 12, 2006 12:00 PM
Post
by Eddie in TO » Sep 05, 2012 12:30 PM
that is all for now...
skip535i
Posts: 5186 Joined: Oct 26, 2006 2:27 PM
Post
by skip535i » Sep 05, 2012 12:48 PM
Can't wait to see what kind of numbers this beast will put down
Posts: 10735 Joined: Feb 12, 2006 12:00 PM
Post
by Brad D. » Sep 05, 2012 1:34 PM
T_C_D wrote:
Damn, that just looks so right.
Eddie in TO
Post
by Eddie in TO » Sep 05, 2012 1:45 PM
^^^^ oh yes. I think an M62 engine cover would be great to hide the real monster.
Post
by Brad D. » Sep 05, 2012 2:09 PM
Eddie in TO wrote: ^^^^ oh yes. I think an M62 engine cover would be great to hide the real monster.
Posts: 15844 Joined: Feb 12, 2006 12:00 PM
Post
by Jeremy » Sep 05, 2012 2:10 PM
Why hide it?
Post
by Brad D. » Sep 05, 2012 2:14 PM
I agree, I think it looks particularly awesome as is, I was just bored.
Posts: 9986 Joined: Feb 12, 2006 12:00 PM
Post
by Duke » Sep 05, 2012 3:19 PM
Jeremy wrote: Why hide it?
It would be like a V8 BMW engine then.
Post
by T_C_D » Sep 06, 2012 10:30 AM
Punch List!
Charge Piping
(1) 4” T bolt clamp
(4) 3” T bolt clamps
Fuel System
Fuel line
Pressure transducer for MS
Fittings
Cooling System
6mm barbed tee
4 feet of 6mm coolant hose
6 clamps for 6mm hose
2 feet of 8mm coolant hose
(3) 5/8 OD 6mm stud isolators for overflow bottle
Fittings for coolant overflow 8mm barb
5 feet 20mm coolant hose
Barb adapter 20mm/16mm
Clutch
Slave master fitting
Master cylinder hose barb
Wastegate
Signal line
WG fitting
BOV
Signal line
Turbo
Oil return line and fittings
Oil supply line and fittings
Plugs for coolant passages on turbo
Crankcase/Engine
(3) 5/8 OD 6mm stud isolators for catch can
Barbed fittings for catch can
Tee for crankcase hose
Crankcase hose
Plug for back of intake manifold
Power Steering
Lines and Fittings
Cooler
Wiring Harness
Install lc1
Pig tail for Icv and tps
Auto meter gauge for oem coolant sensor
Male plug for fan and relay setup and resistors for 2 speeds
Fittings and line for map signal
Misc
Tranny vent hose cap
Secure throttle cable
Tubing for strut bar
Ignition wires
Battery cable and battery box
L_N_Love
Posts: 4106 Joined: Jun 19, 2008 11:18 PM
Post
by L_N_Love » Sep 06, 2012 11:21 PM
Big list...guess we won't hear it fire up for several months. Hang in there.
clongo
Posts: 1050 Joined: Nov 21, 2009 10:58 PM
Post
by clongo » Sep 07, 2012 7:34 AM
Nice! You're on the home stretch!
Eddie in TO
Post
by Eddie in TO » Sep 28, 2012 4:42 PM
so, what have you knocked out of your list? C'mon, let's see what you got...
Post
by T_C_D » Oct 10, 2012 10:01 PM
Eddie in TO wrote: so, what have you knocked out of your list? C'mon, let's see what you got...
I have been picking at it. Finally finished a few big home projects and now have some time to work on the car. Will update in a few days.
Post
by T_C_D » Oct 11, 2012 5:39 PM
Hoping to be done with this list except for the wiring by the end of next week.
Fuel System
Fuel line
Fittings
Cooling System
Overflow bottle
5 feet 3/4 coolant hose
Barb adapter 5/8-3/4
Clutch
Reinstall Clutch Master Cyl
Wastegate
Signal line
Turbo
Oil supply line
Crankcase/Engine
Catch can
Power Steering
High Pressure Lines
Wiring Harness
Install lc1
Male plug for fan and relay setup and PWM Module
Misc
Ignition wires
Install Battery cable and battery box
Posts: 23035 Joined: Apr 08, 2009 10:30 PM
Post
by mooseheadm5 » Oct 11, 2012 6:09 PM
So when I'm at Rhinebeck next week I don't suppose I'll see you pull up in this car, eh?
Post
by T_C_D » Oct 11, 2012 6:11 PM
mooseheadm5 wrote: So when I'm at Rhinebeck next week I don't suppose I'll see you pull up in this car, eh?
Nope but you can drive done and see it!
Post
by mooseheadm5 » Oct 11, 2012 6:14 PM
T_C_D wrote: mooseheadm5 wrote: So when I'm at Rhinebeck next week I don't suppose I'll see you pull up in this car, eh?
I may do that.
Post
by T_C_D » Oct 25, 2012 10:04 PM
Had to move the battery to the trunk to make room for the coils, coolant overflow bottle and crankcase catch can. Got the coils installed. Will order the ignition wires next week.
Installed the fpr and fuel lines.
Installed the PS cooler under the battery tray.
And installed the distribution block and all the low pressure power steering lines.
Posts: 17638 Joined: Feb 12, 2006 12:00 PM
Post
by Kyle in NO » Oct 25, 2012 10:13 PM
Any specific reason the coils are not mounted on the valve covers?
Post
by T_C_D » Oct 25, 2012 10:14 PM
Kyle in NO wrote: Any specific reason the coils are not mounted on the valve covers?
FUGLY and will be going to an aftermarket smooth top valve cover at a later date.
Posts: 9073 Joined: Apr 13, 2006 11:18 PM
Post
by Nebraska_e28 » Oct 26, 2012 8:58 AM
Will the catch can be vent-to-atm or have vacuum? Is the much benefit (if any) either way?
Post
by T_C_D » Oct 26, 2012 9:49 AM
Nebraska_e28 wrote: Will the catch can be vent-to-atm or have vacuum? Is the much benefit (if any) either way?
Mine will just go to atmosphere for the time being. It's better to have it recirculate for emissions and ring sealing.
Post
by T_C_D » Oct 26, 2012 4:39 PM
Installed the overflow tank and crankcase catch can. Still need to order more fittings to hook it all up.
Cut and drilled the new strut bar since the last one was used for the rad support. The bar sits 2.5" above the intake manifold.
L_N_Love
Post
by L_N_Love » Oct 26, 2012 11:29 PM
Looks awesome Todd. Great job.
Mark 88/M5 Houston
Posts: 8548 Joined: Feb 12, 2006 12:00 PM
Post
by Mark 88/M5 Houston » Oct 27, 2012 10:00 AM
Damn, that car sure is pretty. I look at that one and just drool.
And that doesn't even take in to consideration the performance potential!
Post
by Duke » Oct 27, 2012 10:44 AM
You gotta be getting antzy to start it now. Looking very nice. You are going to cause many bruised egos at the drag strip.
I predict that Corvettes will be letting guys go around them to avoid lining up next to you. Those Corvette guys try to keep the legend alive.
paul burke
Posts: 844 Joined: Sep 08, 2008 4:51 PM
Post
by paul burke » Oct 27, 2012 12:12 PM
Duke wrote: You gotta be getting antzy to start it now. Looking very nice. You are going to cause many bruised egos at the drag strip.
I predict 12.0s at a buck 22 .
Isn't that what all Todd's BMW projects run?
Paul
Post
by Duke » Oct 27, 2012 2:59 PM
paul burke wrote: I predict 12.0s at a buck 22
Nope - low 11s all day long. If it stays hooked, 10s.
Post
by Jeremy » Oct 27, 2012 4:14 PM
Duke wrote: Nope - low 11s all day long. If it stays hooked, 10s.
Getting and maintaining traction without tearing the rear subframe off the car has traditionally been Todd's biggest barrier to really fast ETs. He's nearly always had the power to be quicker than his ETs showed, I don't see how a massive upgrade in power will help in that regard but time will tell.
I look forward to seeing him try.
