Page 52 of 179
Posted: Apr 19, 2011 11:51 PM
by jdualan
replaced center bearing.....still getting vibration from shaft....might be time to just get a new remanufactured one...
Posted: Apr 20, 2011 1:21 AM
by Five two eight eye
Was it a NOS part? I just put a new old stock BMW drive shaft center bearing in mine the other week and it shredded immediately cos it was so old. Just a thought.
Oh, and what I did to mine today....Gave one a wash and showed the other one off.
Posted: Apr 20, 2011 9:25 AM
by Das_Prachtstrasse
Where do I start.. In the last 2 days, using incorrect tools, and without assistance on the floor of my garage, I've:
Installed new clutch, pressure plate, center bearing, throw out bearing, lightened 528i flywheel, gearbox, tailshaft, exhaust, front sway and stabilizer, Hartge wheels and dropped it off jackstands for the first time in 9 months. Then, stuck into the engine bay, finished up the wiring harness, double checked c101 wiring, painted a few bits and pieces, installed the strut brace, new wiring harness firewall rubbers, new bonnet release cable, adjusted the bonnet catches, and installed bonnet. Then I got stuck into the interior. Installed the shifter, modified the reverse light switch wiring, leather fed the seats, dusted and detailed the rest with a cotton bud and rag, vacuumed, cleaned the door pulls from all the greasy hand prints, and custom routed the WAR chip USB cable into the glovebox to complete the instal.
I then installed the battery, replaced all the fuses and relays with new ones, and double checked all the electrical connections with a multimeter, and then once the battery was installed to find the only thing not checking out are the reverse lights, which i must admit, is a relief considering all the harness and connections in the car have been newly installed or modified.
Tomorrow she'll be filled with fluids, i'll remove the m20 bonnet insulation as it's not allowing the bonnet to shut with the m106 in there, install the electric fan, and start her up for the first time in one and a half years.
My back is killing me, my knuckles have no skin left, and i'm running out of hand cleaner but i'm damn satisfied and look forward to turning the key again.
Fingers crossed..
If it goes well, over the next few days i'll get the throttle body space plate made up to supply vacuum to the brakes, and have the high pressure power steering line modified so I can safely drive the thing. Then it's off to Sydney and back to run the motor in.. Fingers and toes.
Posted: Apr 20, 2011 9:28 AM
by rmiddendorf
Das_Prachtstraße wrote:Where do I start.. In the last 2 days, using incorrect tools, and without assistance on the floor of my garage, I've:
I then installed the battery, replaced all the fuses and relays with new ones, and double checked all the electrical connections with a multimeter, and with then once the battery was installed to find the only thing not checking out are the reverse lights, which i must admit, is a relief considering all the harness and connections in the car have been newly installed or modified.
Fingers crossed..
That's pure awesomeness. Can't wait for the next update!
Posted: Apr 20, 2011 12:24 PM
by philip1
Sways upgraded to unknown brand 3-way adjustable 22mm/16mm. I set both to the middle setting, the car feels much more planted. I still have body roll but my mud flaps don't drag anymore
Posted: Apr 20, 2011 2:21 PM
by Jake D
I ignored all the little things that I need to replace.... again.
Posted: Apr 20, 2011 7:36 PM
by rmiddendorf
So, unless I did my search wrong, there are only 4 instances of the terms 'valve adjustment' in this thread. Am I missing something or are we neglecting this maintenance as a group?
The reason I bring it up is that I was thinking of doing it to Bandit before The Vintage, but can't figure out of its worth the trouble or not. It seems pretty easy and I might just start amassing the needed parts, which only consist of a feeler gauge and a new valve cover gasket. Probably all under $10.
Posted: Apr 20, 2011 11:38 PM
by brkinshiz
Finally bought some new wiper blades, no more idiotic choice between not being able to see and making my ears bleed from the SQUEEAAKKK
Posted: Apr 22, 2011 12:33 PM
by austin8753
Hoping to get to the bottom of this shitty gas mileage bullshit today
Will report back later, hopefully, with good news.
Posted: Apr 22, 2011 1:07 PM
by Mab1957
Seat frame bolster re-welded. Leather repairs underway at Lim's Upholstery.
Posted: Apr 22, 2011 1:44 PM
by rmiddendorf
Stopped by the dealer to order a new key. $37!
I seem to remember one of you only paying $26 for the same key. Do I ever feel like I've been taken to the cleaners. I'll pick it up Monday.
Thank goodness for DPP for the rest of my needs.
Posted: Apr 22, 2011 2:34 PM
by slammin_e28
Dropped the insurance.
Posted: Apr 24, 2011 12:35 AM
by davintosh
Drove the snot out of it on the way to my nephew's wedding this afternoon, about a half-hour's drive away. Then it started bucking a bit on the way to the reception and died on me as I rolled into the parking lot. It started up again after the reception, but was bucking again; my son & I tried driving it home, and it made it two blocks. Wouldn't start again, so we had to walk back to catch a ride home. So there it sits until tomorrow when we drive out to drag it home.
I'm thinking fuel pump; anybody else have a guess?
I'll bring a spare main relay and some emery cloth along when we go to pick it up, just to see if I can get it going before bothering with the tow.
Posted: Apr 24, 2011 1:35 AM
by derrith
Probably the least productive thing I've done to my car.
Posted: Apr 24, 2011 2:21 AM
by brkinshiz
derrith wrote:Probably the least productive thing I've done to my car.
Manual FTMFW
Posted: Apr 24, 2011 2:26 AM
I did stuff and things and junk.
Posted: Apr 24, 2011 6:19 PM
by davintosh
I steered it while my son did an admirable job of driving tug to drag the 528 home from where it died last night. Was too full of Easter ham & cheesy potatoes to do anything more.
Now I've got to take a razor blade to the stoopid orange sticker that Local Law Enforcement saw fit to affix to my window.
I am glad he at least didn't stick it on the body or the mirror.
Posted: Apr 24, 2011 6:53 PM
by philip1
I installed my new exhaust mostly...
Posted: Apr 24, 2011 7:11 PM
by rmiddendorf
davintosh wrote:I steered it while my son did an admirable job of driving tug to drag the 528 home from where it died last night. Was too full of Easter ham & cheesy potatoes to do anything more.
Dave-
I'm waiting with baited breath to see what went wrong. I'm trying to have enough spare parts around for my trip to The Vintage and still have yet to decide if I want to drop $260 on a new
spare fuel pump. Good luck!
Posted: Apr 24, 2011 7:54 PM
rmiddendorf wrote: $260 on a new spare fuel pump.
Try
steve@blunttech.com for a Bosch and save $100.00 +/-.
Posted: Apr 24, 2011 8:10 PM
by rmiddendorf
1st 5er wrote:rmiddendorf wrote: $260 on a new spare fuel pump.
Try
Thanks Sherman! They also have a lot of cool eye candy on their site. I love seeing an S50 powered E30. Those are kewl...
Posted: Apr 25, 2011 1:39 PM
by shagrath
Scraped my wife off the side of the road when her 87 eta shit an alternator/WP belt. 2 hours later (travel to and from Norfolk/VB, drop kid off, get part, 20 minute install) all fixed.
front suspension/steering
Posted: Apr 26, 2011 12:06 PM
by knunger
Replaced ALL of the wear components in the front suspension:
All control arms
stabilizer links
stabilizer bushings
3 tie rods
steering arm
pitman arm
(torquing the control arm through-bolts on a lowered 535is sitting on 6" ramps is a BITCH!)
Today, new tires and align, tomorrow, enjoy!!
Posted: Apr 26, 2011 4:11 PM
by Alfonso Bedoya
Trunk Pfeba spolier installed finally!
Next is a photo shoot woot!
Posted: Apr 26, 2011 11:13 PM
by ESchmitz
I continued removing the nasty gold pinstripe that the dealer must have put on the car. I'm about half way done and I have to say the car looks tons better without the stripe.
The UPS man delivered my new suspension today so I'll be posting about that in a few days...
Erik
Posted: Apr 26, 2011 11:15 PM
by philip1
Today I almost completely cured my exhaust leak...almost.
Posted: Apr 27, 2011 3:50 AM
My fifth Euro conversion. Wasn't my E28, though.
Posted: Apr 27, 2011 4:10 AM
by CSBolger
Put it through its paces in a local canyon.
New tires, a 3.73LSD, and a healthy B35 definitely made for some fun.
Posted: Apr 27, 2011 10:05 AM
by dgoddard
Made it tow a uhaul trailer so I could move across town.
Posted: Apr 28, 2011 4:19 AM
by Golf Pro
Replaced OEM Electric ariel on Car.
