LS1 / T56 DD e28 BMW Build
I can see quite clearly you have some experience years over me. I'm all ears on any advice I can get. I've been dying to get this swap On the road but I want to get all the information on it I can first. My first question has to be why are there only several wires running to the fuse box, what do that go to, and what colors go to what.
Well the wires that actually connect to the BMW fuse box are for....starter, oil pressure, water temp, alternator exciter, fuel pump, and power to main relay. Then there is a bundle that will go to another fuse box to power the engine circuits, injection/coil 1, injection/coil 2, maf/o2/reverse lockout, evap valve, AC relay, fan relays, fuel pump, etc
Then there is a bundle that goes into the car...tach, econ gauge, CEL, OBDII port, etc.
The colors really don't mean much becasue I ran it all myself......
If you do do the same project get ahold of me if you need help with the wiring or want a plug and play harness.
Well I was hoping to have it running today but that didn't happen. Worked on it all day but ran out of time. It's getting closer and closer though.
My list...
Engine harness off, fully wrapped. I went through and checked every pin just to be sure.
Harness back on the engine
Where it ties into the chassis
GM fuse box all wired up
I got some used GTO fuel rail covers....they need a little trimming to fit. They will get repainted and the GTO will get shaves off. Should they be black or silver? Or something else?
Other things that got done today but really no pictures to show...
new radiator is in, lower radiator hose is done, upper rad hose is ready, heater hoses just need a couple more clamps, brake booster line hooked up, power steering lines ready to go... I think that is it
I should be able to work out there tomorrow a little bit but I doubt I will have it ready to start Coming soon tho.
My list...
It's running!!!
Video is pretty boring but this was the first start.....running smooth. Still have to finish a few things before it can be driven.
http://www.youtube.com/watch?v=hDydIYsUalA
A few pics of the exhaust painted and back on the car.
Also picked this up for my wife yesterday.....I am thinking it will get a 60 degree GM v6.....around 200hp or so.
67 volvo amazon
67 volvo amazon
That's impressive.jakeb wrote:It's running!!!
thanks!
A little bit more finished.
AC lines all crimped and installed
Looks like it belongs there.....Still unsure if I like the covers or not.
I like that they cover up all the coils and what not....I think I will like them better when they are repainted black.
I still need to find a new home for the cruise servo because the cable isn't long enough...well it is but the cable has to stretch over everything.
thanks guys!! It has been great fun doing the swap.
No pictures from yesterdays work but....
Torqued the front wheel bearings, installed the brake master cylinder and lines, trimmed the engine covers some more.
I still need to decide if I am going to have the cruise control cable lay over the engine from the drivers side or if I should move the cruise servo.
I was able to get a set of e34 basket weaves with worn tires from a friend to use while I refinish my style 5s. I should be driving the e28 by this weekend.
Amazing work!! Being a fellow LS swap (in a different chassis) owner I can say you will absolutely love this car.
Couple of quick questions for you:
Did you use a custom AC setup? Or re-use the BMW parts like the condensor? I'm looking at options for my 240's AC and am not sure what the best method of attack is, all custom or reusing as much of the OE stuff as I can.
Will you be able to make the stock tach and speedo work with the swap? I know I had to use a dakota digital box on mine for the speedo.
thanks! I am really excited to start driving it. I am thinking I will really like it too.
I want the AC to be COLD with r134a so I upgraded the condenser to a newer cross flow type. I then made new lines that go from the GM compressor to condenser to drier and back to the stock evap in the car.
I am having the GM PCM control AC, fans, etc
The BMW speedo runs off a sensor in the diff.....completely separate from the engine stuff. Yes the speedo works...after a reflash with HPTuners.
First time off the lift in 5 months..first time moving under it's own power. It needs an alignment really badly...also need insurance and a plate but it drove around the block a few times. I love the way the clutch feels and the trans shifts. Very happy I had the trans gone through.
I live in a residential area (25mph) so I really wasn't able to get on it much. But when I did it put a smile on my face for sure.
Hoping to get an alignment today and plates tomorrow and start driving the thing!
A few pictures.
back on the ground
Location of shifter...I need a new boot. I might make a different selector so I can use a newer style BMW shift knob and also bring it just a tad higher. But this will work for now.
Another engine bay shot....
A few pictures.
back on the ground
Got the car aligned today....drives a lot better. Hoping to find some time tomorrow to get tags so it is legal to drive.
Gave it a quick wash today after months of dust and grime in the garage.
These tires are a little too tall so it will look a little different but you can get the idea...
The paint it mostly dull....My cousin who does paintless dent repair and some amazing things with a buffer said he thinks he can bring some of the shine back. I will probably paint it next summer....still unsure if it will stay silver or change to black.
A few of the interior.
The guys at the alignment shop were blown away. I actually did most of the alignment as the rear is all adjustable now. Makes everything easy when it is all brand new.
Oh yeah...while driving to the alignment place I got on it a little bit....holy shit!
