Page 6 of 22
Posted: Oct 27, 2012 12:19 PM
by OcCoupe
This is very exciting Chris good for you taking the leap. As we've discussed it is a scary process; but I think you did your due diligence and found the right shop for the job. I can't wait to see it when its finished. Maybe I should fly out to help put it back together!!!
Posted: Oct 28, 2012 10:38 AM
by tsmall07
Chris,
I'm glad you found someone you trust. I hope to be able to see the car when it is done. I'm sure it will be among the nicest BMWs in the country.
Posted: Oct 28, 2012 11:15 AM
by B7Turbo
Chris, good going! I am sure it will look awesome.
Cheers,
Sia
Posted: Oct 30, 2012 5:19 PM
by Eddie in TO
tsmall07 wrote:Chris,
It's not easy to find someone you can trust nowadays.
Best of luck on the next step in bringing this B7 to a new level.
As mentioned, you're more than capable of making this B7 into a fine example. Looking forward to seeing it one day too!
nice
Posted: Oct 31, 2012 7:28 AM
by alpinass
What is the all the paintwork going to set you back? Pulling the engine? Painting the undercarriage? My guess is 5K.
PML
Posted: Nov 01, 2012 5:02 AM
Looking like either tomorrow or Friday is the big day to drop the car off at the shop. There's not much left on the car right now (total time invested so far a little under eleven hours). I got a call from him tonight, but I was on the phone talking important stuff with someone, so I missed it.
Yesterday morning, I spent about 40 minutes and stripped the rear tail panel of all of the lock stuff, tail lamps, and pulled all of the wiring from the trunklid, etc. I decided that it's too much of a risk driving the car to the shop. It's about 20 miles away and that would be the time something would happen to the car. My luck just works that way. Also, trying to get a ride from someone would be another nightmare, so it's best to trailer/tow the car there. I guess that means I could probably pull the fuel tanks, but I'll wait until the car is at the shop for that. They have to come out to replace the tail panel.
Doors will be delivered in the morning. I can hopefully work on stripping the doors down, then take them over to the shop in the touring. This way, I can make sure everything is the way I want them, not to mention, it will allow me to really clean the window stuff well, etc.
So, tonight, I figured that since I was going to stay at home but not give out candy (I live very close to the state fairgrounds and we get essentially bus loads of kids, many who are old enough to shave), I'd pull the locks and stuff out of the doors. I discovered that the second lock in the driver door was going to cause a problem with that as it's right up against the door lock heater/clip for the lock. I pulled off one of the wires and the alarm horns started sounding. I tried a few things and nothing worked, so I decided now was the best time to get to the bottom of all of the aftermarket wiring. Let's get it out of there.
I removed all of this:
I also found a 10 Francs coin from 1979 that had been stuck under the front edge of the dash.
Posted: Nov 01, 2012 9:28 AM
by Pedi
We need a picture from you, showing the car ready for transport...
Posted: Nov 01, 2012 10:24 AM
by Coldswede
Good move on ridding the car, and yourself, of the alarm system. I've come to abhor any kind of aftermarket wiring. Between the God fosaken "vampire clips" and the less than workman like job of wiring, aftermarket installations are a nightmare
Posted: Nov 03, 2012 3:19 AM
Every bit of aftermarket wiring was going to leave the car anyway. It always does in my cars. Please don't think I would have left that crap in there. The problem here was with the shortened timetable to strip the car. That was going to be left until after paint, as some of the other mechanical stuff is being put off as well. [Un]fortunately, while I thought it was completely dormant, I found it wasn't, so it all had to go much sooner than anticipated. This of course is great since I don't have to worry about it anymore.
Today, I spent the morning before I went to work stripping the four "new" doors of all seals, glass, wiring, etc. I initally was just going to pull the glass out. The window regulators were frozen (I broke 11 of the plastic emergency window tools on the right front door). It was on number 11 where I figured it wasn't going to move. The 528e was last registered in 1993, so I guess it had been sitting a while. I'm just glad it was still around. Then, I had to pull all of the wiring since I didn't pull the doors off the donor car. They just cut the harnesses in half. So, that means before these doors can go on the car, I have to strip the wiring out of the old doors and run it into the new doors. I left the latches and the lock actuators in place just to make it easier to get the doors installed and aligned. All said and done, it took about 35 minutes per front door and 45 minutes per rear door. Before starting, I inventoried the new parts I have on hand for doors - seals, window guides, all of the trim, clips, etc. Just wanted to be sure before tearing into them.
After that was done, I went to work. Got home and put the style 8s on the car. This took a while since they were behind the E12, which currently has half of the B7 sitting on it (just all the old trim crap, stuff from the trunk, etc). Got all of that taken care of. All that's left to remove is the rear muffler and the fuel tanks, but I'll do that after the car is at the shop. My fingers are killing me right now.
So, since I work tomorrow at 7am, I'm not sure if I can get the car over there. He's shooting for tomorrow, but I guess we will see. Maybe late afternoon will work for him. At this point, I've got two mostly-stripped cars in the garage. I guess that's somehow progress. Taking this one apart makes me wonder if I'll remember how to put the E12 back together. At least I can cheat with the E28. Kinda funny how I haven't had to look at the Bentley a single time so far. Wonder what that says.
I'll have photos of the car as it sits tomorrow, hopefully.
Posted: Nov 05, 2012 12:36 AM
Since Mike had some issues moving into the new shop on time (none were his fault - he even spent Friday night there in his car), the timeline shifted some, which is fine. I had to work all day yesterday. So, it's going to happen sometime this week for sure. He figured tomorrow or Tuesday, but I am not so optimistic.
So, in light of that, I pulled some more stuff. The hood isn't needed, since it's being replaced. The doors are still on for now, mostly since I don't want to pull them off and have to put them somewhere. I pulled the rear muffler and the fuel tanks today (probably a mistake as I'm in a bunch of pain right now as it did not go smoothly at all, but it probably means he can get right onto the rear panel replacement). Also took the trunk seal out. Found it was original since when they painted the car last (except the roof), they just taped it off. I started throwing away stuff I know for sure I don't need, as well. I can barely move around the garage right now and that's making me more upset than I already am.
I cannot imagine how anyone thinks of paint as no big deal. Right now, I just want this damn thing out of my garage.
Here's a couple shots of the car as it currently sits:
Posted: Nov 05, 2012 10:15 AM
by skip535i
No joke when you do it right! I admire the dedication, Chris. I hope one day you'll actually like the car
Posted: Nov 05, 2012 5:23 PM
by Brian D
Chris, let me know if you need help getting it moved. I'm off work until Friday.
Posted: Nov 15, 2012 12:08 PM
by cddallara
Updates, man! Updates!
Please? And Thank You.
Posted: Nov 15, 2012 12:58 PM
by Jake D
That looks like fun wrapped up in a nice, snugly nightmare. Thanks for sharing your progress!
Keep up the good work.
Posted: Dec 02, 2012 4:55 AM
I guess I should give an update.
I got all four doors in Polaris from a local yard a couple miles from my house. They delivered them so I wouldn't have to put them in the touring (BTW, four doors, a trunklid and a tail panel will fit in an E34 touring - did that for the E12). I was happy they let me have everything in the doors too, as they'd usually pull the regulators, glass and latch mechanism, etc. Anyway, they showed up and I saw they didn't unplug the wiring and pull it through. Instead they just cut the harness.
So, I spent a couple hours and completely stripped the doors:
Things were a go for Wednesday, November 7th. Tuesday night, I was ready to just let the car sit in my garage for another five years or whatever, but I had already paid $2,000, so I guess I had to go through with it.
Mike's friend Mike came to pick the car up. We got it loaded on the trailer.
This sucks also because now I have to strip out the innards from the doors on the car once they come off, then run the wiring into the "new" doors before they can go onto the car. On top of that my nearly-endless searching and emails back and forth with people all over the world has netted absolutely nothing in the way of replacement rubber conduit for the wiring.
No shot of the car on it's way up as I was pushing helping the winch to put as little stress as possible on the front of the car.
I followed in the touring.
And we arrived at Flores Performance. Sorta.
The car came off the trailer and I pushed it into the bay on the far end of the shop. It was dicey for a moment since I pulled the fuel tanks, but I got him settled down once he realized how much more room he has at his new shop (an inoperable car would have been a nightmare at his old shop).
Here's the '55 Chevy he had just finished for a customer:
And here's a '64 Nova that he painted a while back that was there getting something done before the Good Guy's car show:
So, I made sure Mike had all of the parts, we went over a couple more things and then I left. He told me I was welcome to come by whenever I like - open door. He's not exactly close, but it's not a bad drive.
Posted: Dec 02, 2012 5:06 AM
The following Thursday, I was working in Chandler and was able to break away from that to go to my guitar lesson in Gilbert, so I swung over to Mesa on the way to bring him the shims from the doors I brought as I left them in my cupholder when we delivered the car. To my surprise, work had already started:
This door had a couple spots of rust behind the seal, but lacked the hole that is in the door currently mounted to the car.
The reason I searched out Polaris doors was so I could avoid painting the door jambs. I wanted to avoid painting the door jambs since they looked nice and I also had a perfect tire pressure sticker:
To my surprise, Mike had determined that he didn't think the paint on the doors was nice enough inside - not a wear thing, rather he didn't think they looked that great from the factory, so he decided to prep them to paint the entire door, something I wasn't expecting. I was a bit surprised, but am still glad I got the Polaris doors, as the last thing I want under my new paint is a blue or Bronzit door. I picked up everything they took out of the doors, and I guess I'm supposed to clean it up and bring back the parts I want to use from either set of doors. I still forgot to give him the shims.
Posted: Dec 02, 2012 5:26 AM
On the 21st, I stopped by again as I was again working in Chandler. I had to rebuild a shifter and reinstall a reman driveshaft for a friend in Tempe while he had lift access, before the shop next door closed for the long weekend, so I left work early. On my way, I swung by the shop to see my car and drop off a couple of critical pieces while I still had the touring.
He first showed me that they stripped the roof down to the sealer. He still needs to weld up the hole in the roof from the antenna that was mounted there. Obviously, this cannot be done until the windows are out and the headliner removed. They cut the seals back and the bit of bubbling under the left corner of the rear window was indeed a hole, as I had expected, so now we know that.
They had removed the front fenders. I wasn't expecting that.
He did it because we had to move the antenna back up front, where it was originally. When the car was painted last, they patched that hole and put one in the stock location in the rear. That's stupid since the spoiler would hit it if it was extended while opening the trunk. I had noticed a slight bit of dieback in a circle on top of the fender, so when I first pulled the inner fender liner while checking for rust, I saw the patch that was applied to the underside of the fender. He is going to remove the patch and put the hole right where it's supposed to be. Once I heard about all of this work, I was figuring I should have just gotten fenders too. Fortunately, they're not rusty. Tad bit of surface on the very bottom, but that's taken care of now.
Once I looked at the car, I was very happy he pulled the fenders.
Fortunately, right now, this is just surface. He's going to blast it and treat it. It's very common - something I've seen on lots of E12s, but unless the fenders are off, you can't see it until it's too late and this is pretty thick metal, too. Whew. Just one of those things I won't have to wonder about in the future!
Inner fenders look nice. All of this will be painted as well, which makes me feel better about not doing all the suspension and subframe work before paint.
Another shot of his M3 (please don't comment on the wheels - I only care about the quality of the paint):
Look what finally showed up (after I ordered it 16 months ago):
I showed it to Mike and I thought it looked pretty nice. He said he would make it straight.
Mike told me that he has been getting several people who ask what is so special about the car. They cannot believe it when he tells them what it is and how many are in the US. He appears to understand how special the car is and while he says he cares about every job, it's nice to see him take an interest in it. I had shown the car to people who made reference to it simply as "an import" or another guy who said, "all I see is metal - I don't care what the car is." Him and the "I ain't hangin' no doors" guy were real award winners in this process.
I also decided that I could get a reproduction of the tire sticker made, as a photo of my sticker was used to make reproductions already. I contacted my contact who contacted his contact and I've got three on the way. I decided to ask Mike about doing the door jambs on the car as it would make for a better finished product. I've found before that what looks great now will look not-as-great once everything else looks amazing. He told me that he's not charging me extra to do the doors themselves. I said I really appreciate that. How much extra to do the jambs on the car? He told me and I said, "do it."
I was in a hurry and again forgot to give him the shims.
Posted: Dec 02, 2012 6:00 AM
Thursday, I stopped by since I was out that way and I wanted to see what was going on.
When I showed up, I saw my front valance. Sweet.
It looked like this when I got the car:
Used Jon's picture as I think I had already pulled it out with my hand some as it looked like shit.
Anyway, now that Mike had the airdam, he straightened the valance out. You might be wondering..."a new valance is something like $270. Why didn't you just go with a new one?"
That's a super question. The reason is that Alpina modified the valance so that a charge pipe to the intercooler could run through it, in addition to the holes for the airdam (shown on the left side of the photo, right side of the valance). I figured since this one really isn't that bad, maybe it could be saved. I told him what a new one would cost and what we'd have to do to it and he said not to bother.
Now that he had the spoiler, he was able to make sure everything fit properly.
The hood and fender in the background go to the '67 Impala sitting there. They were a righteous mess when I saw them last week. Now they're practically perfectly straight. No reproduction sheetmetal for those cars, so Mike straightened that stuff out. Quite amazing.
Then I saw the car. Hmmm. Looks lighter.
He says he's blocked out the quarter on the left side, and much of the one on the right except for the damage, which still has to be fixed. Of course, I can't remember what numbers he told me for the paper, so I need to make sure as to the steps followed on the blocking of said quarters and what is still to be done. Most of the jambs have been prepped except for the drivers as he doesn't want to do anything until I have the sticker in my hand. I told him it's coming from the UK. Hope it gets here soon.
They cleaned out the channel where the trunk seal goes, so that's looking good now. Still haven't done the rear panel. The carpet is getting dirty. It will clean up fine, but really wish I could have removed it but the wastegate control valve prevented that.
And my hood showed up! Had to come from Germany, but it's here safe and looks great.
I made sure to hand him the stack of shims.
I'm still stressed out.
Posted: Dec 02, 2012 6:28 AM
by johnnye23
That car is in good hands ! Looking fantastic Chris , please keep the pictures coming.
Posted: Dec 02, 2012 11:13 AM
Thanks for the update. Lookin' nice. It seems you found the right shop.
It takes much less to stress me out.
Posted: Dec 02, 2012 3:19 PM
by L_N_Love
Thanks for the update Chris! I am enjoying following this project.
Posted: Dec 02, 2012 9:08 PM
by BMWJustin
Great progress on an amazing project. I look forward to seeing updates.
Best
Justin
Posted: Dec 03, 2012 12:14 AM
by Dinan e28
It is nice to see some one who care's about his work that much. Its also cool that you saved the front valance.I'm excited to see the finished product.
Posted: Dec 03, 2012 12:29 AM
by bkbimmer
Very cool, Chris.
Posted: Dec 03, 2012 2:35 AM
by austin8753
I'm loving the progress so far. It should look nothing short of fantastic when it's all done. That E30 M3 looks pretty rad, too.
Excited to see the end result, Chris!
Posted: Dec 03, 2012 6:24 AM
by Splondike
Great work
Posted: Dec 03, 2012 7:22 AM
by Pedi
You are lucky with the painters attitude. I wish Norwegian painters could have the same "good workmanship" attitude, but it is a long way between those guys here...
I assume you are gonna pull the front/rear windshield (only there due to transportation issues I guess).
But why did you not pull the engine, so that you could have a full respray?
Regarding the floor carpet, it is no problem to take the boost-adjuster knot off. The rest (read: the valve) remains in the tunnel, and you could pull the carpet out. I guess you have more problemos with the internal heat radiator box obove the carpet.
I am looking forward to see this car back in business.
nice progess!
Posted: Dec 03, 2012 10:36 AM
by hubble1953
Chris: You have a great painter, wish I could find someone here that was that interested in 'import' cars:). Going to look so good. Did I miss what you are going to do with the suspension?
john
Posted: Dec 03, 2012 2:01 PM
The windscreens are coming out of course. Right now, they're still in though the seals are cut back. They should be coming out sometime soon as there's some rust to fix.
I'm not pulling the engine. Easy for some people to spend my money. I don't have the facilities to do it all and don't want to open up another can of worms. This is an original car and I'm not doing a complete restoration. The paint is nice under the hood and there's no rust.
In addition to the boost controller, there are other brackets in the floor that go through the carpet and prevent it's removal. It's a nice carpet and it doesn't need replacing. I'd have preferred to remove it. I tried and it was apparent I was going to damage it, so I stopped.
The suspension is simply going to be refreshed. The subframes will be refinished and all new bushings and rubber bits installed.
Posted: Dec 03, 2012 2:25 PM
by mooseheadm5
That's a fantastic set of updates. Sure you are stresses, but are you excited yet? Looks like you found the right painter for sure.
