austin8753 wrote:Raced out to Pick N' Pull at 8:30 for what I believed to be an "88 535 i/is." Shit out there goes faster then hotcakes. Anyway, it turned out to be an '87 ETA. Stupid fuckers :roll:
Anyway, grabbed the door pillar cover, radio fader switch and like new Bremi plug wires. Also, found a brand new Dropkick Murphys CD in an '82 320i. SCORE!
Your yards super suck ass now. They were awesome until LKQ came in and changed them all.
MShimon
Post by MShimon »
Installed Spax springs on the M5, satisfied.
austin8753
Post by austin8753 »
Oh, I know! The only semi good thing about this new Pick N' Pull shit is the online inventory.
benfidar
Post by benfidar »
Took her out for a thrashing drive, taking advantage of the warm weather and clear roads :D
Swapped out my defunct driver's side mirror.
Several times did not fix my coolant level sensor :evil:
installed the blanks next to my euro fogs! Now the under bumper looks legit!
PrionaceGlauca
Post by PrionaceGlauca »
Gave her a good wash down.
Then proceeded to discipline a pair of disrespectful ricers on the way back from breakfast.
Swapped a dash yesterday. 2 hours start to finish. :D
Post by rmiddendorf »
wkohler wrote:Swapped a dash yesterday. 2 hours start to finish. :D
Geez... it might be worth it to pay you and fly you out here for a day than try it myself!
EDIT: Windshield in or out?
Windshield in.
Duuuuuudddde! :bow:
E.rouzbeh.28
Post by E.rouzbeh.28 »
Duuuuuudddde! :bow:
x2
Took me over 5 hours. Props to you, sir.
Windshield in. :D
Duuuuuudddde! :bow:
X3
I'm too ADD, I couldn't even come close.
Sparkeysf
Post by Sparkeysf »
Fixed broken steering box bracket using the mwrench kit. Installed new Lemforder dogbones. Replaced cracked motor mounts. Replaced chewed-up alternator ground strap.
Took it for a test drive and noticed a crazy howling sound coming from the front right wheel. Bearing? Jeez... everytime I fix one component another breaks almost immediately.
Post by slammin_e28 »
These:
Nuff said.
Sparkeysf
Post by Sparkeysf »
I could use some of "these". Mind if I ask where you got them?
slammin_e28 wrote:These:
Nuff said.
Sparkeysf wrote:I could use some of "these". Mind if I ask where you got them?
Ordered them through work.
Part # 51 21 1 809 735
austin8753
Threw on the air dam! Once I'm feeling better, I'll paint the wing and put it on too.
E36 ///M3 Vaders in the E28 ///M5*.
"Buffed out" the left front fender and door on Snob.
*Sorry purist, but not enough ca$hola on hand to have the original Natur redone. The complete interior was trashed.
1st 5er wrote:E36 ///M3 Vaders in the E28 ///M5*.
Fuck purists. Picsorban.
What, no black vinyl comfort? ;)
Pushed the red 535is in the garage for THE LAST TIME.
Re-do the entire fuel system, then that bish is gonna roll.
Das_Prachtstraße wrote: *Sorry purist, but not enough ca$hola on hand to have the original Natur redone. The complete interior was trashed.
... purists. Picsorban.
Patience my man, patience...
No, but thanks... those are long gone.
But, I did have a leather set of comforts in for her first road trip.
Alfonso Bedoya
Post by Alfonso Bedoya »
Re-wired Blaupunkt amp and Kenwood cross overs under back seat(not the speakers!), lubed rear head rests nice smooth movement now! Replaced R back up bulb, cleaned the ground under R/R seat, super duper shiny now!
jaredbhouston
Post by jaredbhouston »
cleaned the car between classes, paypal'd Jean for some tweeters, and took the old air freshener out :( time for a new one.
Registration and insurance. :banana: :banana:
Zach716
Post by Zach716 »
I drove it really hard on some mountain roads in Cullowhee, NC.--and the 5er did great!
Got the interior back together, minus the back of the driver's seat which won't stay on.
Also got the stereo back working. No blown channel in the amp, just my crummy head unit acting up.
Drove the crap out of it. Hopefully Sunday we're getting the 3.73 LSD in it.
Cory
Post by Cory »
Got a factory battery clamp, figured out how to use it and bent it out a little to accomodate a Interstate MTP-93.
Jacked up Snob's rear end in preparation for some shock setting adjustments.
Replaced the fan clutch on the 535is. Twice.
Frybrid 524td
Post by Frybrid 524td »
Made a really nice wire harness for the VO system.
EC
Post by EC »
Cap, rotor, wires, plugs, coil, Coolant level sensor, adjusted and lubed hood release cable, replaced one bulb (turn signal front, oil change, fuel filter, and fixed my sticky trunk release button. All in all a pretty good day. Although my car is still a POS... :?
