Turbo Clutch Discussion - Update 12/10/2009
How about dont worry about the clutch for now. Get a system installed and running and go from there. Power goals are a silly way to go about it. Just get it running and keep the boost down. six or eight psi will be fine and you'll be quite happy with it. If the clutch starts to slip, take care of it then.
Its like the guys that go through the entire engine, spend a shit load on forged parts and all kinds of fancy crap they dont need and run it with about 8 psi just like they could have on a stock engine. Its a backwards way to go.
Post by Coldswede »
BBR
Did you ever find the time to install the new clutch?
Or did I lose a bunch of posts somehow? :dunno:
QBANG
I need some input on new clutch.....
Post by QBANG »
Guys I need some help, I need to get a clutch this week. As it turns out UUC is having a 15% off sale right now. I talked to Rob, he said that I sould go with the Segmented Kevlar. If I understood right TCD just burnt one up. This will be going in my E30 M30b34 swap car. Looking for ideas.
M. Holtmeier
Re: I need some input on new clutch.....
Post by M. Holtmeier »
QBANG wrote:Guys I need some help, I need to get a clutch this week. As it turns out UUC is having a 15% of fsale right now. I talked to Rob, he said that I sould go with the Segmented Kevlar. If I understood right TCD just burnt one up. This will be going in my E30 M30b34 swap car.
I think Todd was just putting down mid 12s last weekend with that "burnt" clutch.
QBANG wrote:Guys I need some help, I need to get a clutch this week. As it turns out UUC is having a 15% off sale right now. I talked to Rob, he said that I sould go with the Segmented Kevlar. If I understood right TCD just burnt one up. This will be going in my E30 M30b34 swap car. Looking for ideas.
That is not correct. Todd hasn't tried the segmented kevlar clutch yet. I've been using one in the 228mm size for years and its holding ~400rwtq without a problem. I treat it right, I dont put any heat into it. Your results may vary depending on how you run the car.
bornagain
Post by bornagain »
todd is running a ceramic disk
QBANG
Post by QBANG »
Well I have a Kevlar disk form UUC on its way. I will let you all know how it works out.
TCD
Thank you for your time and help.
