Noob to M30's
Good & Tight
Post by Good & Tight »
turbodan wrote:I doubt you'll be making much boost in the 3500-4000 range. It should be ridiculous when it does spool up though.
Should be fun :D
The MLS arrived, it's .070" with 5 layers, it has two .020" flat shims with three .010" embossed layers with one in the middle.
I will coat each surface with copper spray since I have had no issues with the previous MLS that I coated. I was thinking to take out one .020" and the .010" layers to make it .040" thick but am undecided atm. Checked the valve to piston clearance with the old .070" and there was .080" clearance even with the cam advanced all the way.
Also modified the block and drilled coolant passages to match the M90 head. Should cool the head more evenly right..
:shock:
I concur - I haven't had any problems with the MLS gaskets I've run on various cars. I always coat them in copper spray, let them tack for about 30 minutes, then install.
Good & Tight
Big Bronze Rim wrote:I concur - I haven't had any problems with the MLS gaskets I've run on various cars. I always coat them in copper spray, let them tack for about 30 minutes, then install.
I went ahead and sprayed every side.
Looks like I have to cut a hole in the hood now, Or try to find a smaller exhaust housing.
Damn that is one massive turbo, especially the turbine housing.
BadM535i
Post by BadM535i »
Your crazy!! :laugh:
Can't wait to see some vids!
Scottinva
Post by Scottinva »
You need to be careful with that sucker, you'll be sucking small dogs and children off the streets as you go by!
babisbabou
Post by babisbabou »
Keep up the good work!!!
P.S. Is there any guide on how to change the head gasket? Things like how to remove it and how to be sure the car gear stays in position.
P.S. done :)
Good & Tight
It runs, need to figure out the air filter and cut a hole in the hood, then off to the dyno to see what it can make/take. KABLAAAM!!
:rofl:
Now THAT should create some insanity.
Good & Tight
Big Bronze Rim wrote:Now THAT should create some insanity.
Just test drove it and damn it's laggy as hell, no boost in 1st, 2nd there is a little 3rd it starts to wake up and 4th it see's 10psi. But who wants to wait till 100mph to get boost. Maybe with some tuning it will wake up earlier but I think the HX40 is going back on.
babisbabou
Wow a bit lagy there :shock:
The car looks great and indeed KABLA :D :D
kabla is a Hellenic work meaning something so good that is also sexy ;)
Good & Tight
babisbabou wrote:Wow a bit lagy there :shock:
Thanks
Just found a spark plug wire off, not going to give up just yet.
e30-m30_kid89
Post by e30-m30_kid89 »
Get that plug wire on. you should go a LOT faster lol
Did you switch intake manifolds? Wanna sell me your flipped b34 manifold? :D
That IS a huge exhaust housing that you are using. I'm sure a bit of tuning will help, but I don't know if it's going to help THAT much.
Shadow
Post by Shadow »
Very sick sick sick.
You're the reason why I put an m30 in my e30.:oops:
How much power did you estimate you made
on your last engine?
What are your power goals
on this one?
:banana:
Good & Tight
I wired the launch control and was able to get 5psi in the driveway.
red535t
Post by red535t »
Good & Tight wrote:I wired the launch control and was able to get 5psi in the driveway.
dirty,dirty,dirty :lol:
DMS
Post by DMS »
What is that exhaust housing? 25^2
Good & Tight
DMS wrote:What is that exhaust housing? 25^2
1.54 a/r.
Update.
The boost leak was from the compressor housing to intercooler connection, which was fairly large.
Once it was sealed up the whole ve map was screwed up like it was starving for fuel and would not want to rev at all.
So I switched the injectors from 2 squirts alternating to 2 squirts simultaneous and W0W what a difference. Throttle response is super crisp.
I guess the cam and B35 intake really opened up the air flow to the engine. I need to fix my lc-1 to do some tuning then off to the dyno.
One thing though the idle is so lopy like a cammed out V8 :banana:
e30-m30_kid89
Nice nice....so by next week you have some insane vids for us??? :D
babisbabou
e30-m30_kid89 wrote:Nice nice....so by next week you have some insane vids for us??? :D
That is what we are waiting for :D
iXer
Post by iXer »
Exactly what model Schrick cam is it ?
Do you have a method for intake pressure leak testing other than a visual inspection?
Good & Tight
iXer wrote:Exactly what model Schrick cam is it ?
Just visual, I knew it wasn't a great connection to begin with but I have the right size reducer on the way.
The #'s on the back of the cam 02201 84004 A8
Good & Tight
Haven't had much time to work on the car but I did pick up an LM-2 and man what a difference over the LC-1, so much easier with no grounds to mess with.
I have been busy doing a B35 swap in an E30 for someone so I figured what the heck let's make a turbo manifold to work with A/C. Had some schedule 40 weld els laying around, need a few more to finish.
babisbabou
Nice looking manifold! Waiting to see some pics when it is done :)
Good & Tight
babisbabou wrote:Nice looking manifold! Waiting to see some pics when it is done :)
Almost done just need to add the wastegate provision and weld on the flange.
e30-m30_kid89
Nice, how much?? :D
Just wondering, since you're using your LM-2, wanna sell me your LC-1?
russc
Post by russc »
Nice, fun with a welder
RussC
Good & Tight
O.k it's done who wants, $700 shipped within the USA. I really hate making 6 banger manifolds PITA.
Update on the car, I swapped the HX40 back on and did a few data log runs to get the tune decent. It deff feels a lot more responsive and faster with the Shrick cam with less boost, will be heading to the dyno in a week or two. :banana:
DMS
Post by DMS »
Hmm you ditched the bigger garret? That would be a pitty as it's quite comparable of what I have under the bonnet. Although it has some differences.
