Thank you. Yes, I figured this out, based on the "arrow" mark. This means from the block. The other one to the heater core. Thanks so much.
best, Jeff
e46 Heater Valve Retrofit
thrty8street
Re: e46 Heater Valve Retrofit
Looking to buy a new e46 heater valve - should I go with the Febi Bilstein or Vemo brand?
thrty8street wrote: Aug 16, 2025 9:02 AM Looking to buy a new e46 heater valve - should I go with the Febi Bilstein or Vemo brand?
thrty8street
szacsi72 wrote: Jan 19, 2023 7:05 AM Hi guys,
This part number works perfectly with the E46 heater valve. I believe the part number says it's for the outer temp sensor, but it's the same.
61132359999
I've bought a vemo-kit that comes with pins included, no soldering or hacking required. Set me back $12.
Does it matter which side you pin each wire on the connector?
thrty8street
Update: With the connector plugged in, I wired the yellow/green wire on the pin that's closest to the firewall and the brown/green wire on the other side and the system seems to be working great.
Anyone still making/selling these plates?
Yup, still have a couple of them left
