Straight Pipe
marshalljh93
Straight Pipe
Post by marshalljh93 »
Would it be a good idea to straight pipe my 528e? I want a more aggressive sound, but have no funds at the moment. I don't get tested for emissions where I live so I am clear there. The only question I have is does the engine need back pressure to run correctly? Or would it run better straight piped?
Post by C.R. Krieger »
No.
Yes.
No.
Then why the hell are you contemplating it?
You stand to gain nothing from this. You should install a freer flowing muffler if you want more sound.
Shadow
Post by Shadow »
It's not a good idea.
No your car does not need back pressure to run correctly.
No it would not run better straight piped.
Do it. It will be awesome.
derrith
Post by derrith »
wkohler wrote:Do it. It will be awesome.
Your car will make a ton more power once you get rid of the restrictive exhaust. You'll be able to keep up with m5s.
Ultrascan9999
Do it. Unbelievable power gain!!!
Post by Ultrascan9999 »
Took out everything . Now one larger pipe runs from the engine out to the muffler (magnaflow) and out the middle like before but with a thick chrome tip. The E28 Looks great, sounds great, engine runs cooler, and when you press the accelerator pedal and take off you can scrach through third. However you can forget about that state inspection, that is if your state has that. Cost $160. Result Priceless!!!!
88 535IS
White 5 speed :evil:
foamy
Post by foamy »
im not so sure of that.when my exaust fell off it just got loud there was no extra power.
marshalljh93
Thanks for the input, I was just unsure about the benefits, if there were any, to straight piping it. Looks like I will just have to save my money.
TSMacNeil
Post by TSMacNeil »
You mean..
louder does not mean mo powa?......
:shock:
Post by slammin_e28 »
Backpressure..... :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :facepalm: :hysterical: :hysterical: :hysterical: :deadhorse:
south26
Post by south26 »
I ran my 528e with a straight pipe for a while and I hated the sound. The reason I did it was because one day my cat fell in two (no not the furry kind), I happen to have a 533i that had a straight pipe so I took it off and stuck it on my car until I bought another cat (the metal kind) I was much happier once I had the car back on.
Andy
