Moosehead Eng. UCABs have arrived! 2/2/11 (grp. buy closed)
**Please, no PMs. The inbox fills far too quickly for me to keep track. Feel free to ask any questions in the thread. Please send all orders or questions that you don't want to post to buyucabs at gmail.com **
OK, you have waited long enough.
Round 2 of Moosehead Engineering UCABs!
These will be the same as the ones offered during the last run. Thanks to the positive feedback of the early adopters, I will have another run made. As I mentioned in the original thread here the price will be slightly higher for this next set, but since I will keep them in stock from now on, there is still a discount for doing this group buy style. Shipping is on me!
Pair of unassembled UCABs - $125 shipped
Pair of assembled and lubed UCABs - $140 shipped
Set of 4 races, which will rebuild one pair of UCABs - $22
Rebuild tool - $23
Silver kit – includes pair of unassembled UCABs, set of 4 spare races, and rebuild tool -$165 shipped
Gold kit - includes pair of assembled UCABs, set of races and tool with tube of high temperature grease - $180 shipped
Platinum kit with bushings pressed into your choice of new arms assembled, lubed, tensioned and ready to bolt up– price on request.
Additional pairs of UCABs purchased in the same order will cost $5 less per pair.
Please send 50% deposits to buyucabs at gmail.com
These fit E31, E32, and E34 with the aid of a pair of spacer washers, which are included on request. Please make sure you specify that you need them in your order. No washers are needed for E28 or E24.
Unassembled UCABs will need to have the races pressed in place. This can be done with a press or a large vise. If you don't have access to either, I would recommend buying them assembled since the races cannot be pressed in by hand or tapped in with a mallet.
UCABs which are sold assembled will not be fully tensioned. I learned that the preload must be set once the bushing is pressed into the control arm or else there is a risk of the joint binding from being too tight or knocking from being too loose. If they are run too tight or too loose for too long, the races may wear prematurely and require race replacement due to uneven wear. Though the tool is not required to assemble or tension the bushings, it does make the job a lot easier. You can use a pin wrench or a suitably sized set of snap ring pliers or right angle needle nose. I have all these things and will choose the purpose made tool any day of the week.
All UCABs should be greased. Though the manufacturer states that it is possible to run without grease, it is highly recommended that you use a small amount of high temperature bearing grease on the races when assembling them. Alternately, they can be greased through a hole in the body of the bushing before being pressed into the control arm.
If you purchased a set in the first group buy, please indicate this when you order. I will probably remember, but best to remind me.
But what about LCABs?
Well, I have not had enough time to test them. The metal on the shell is thinner and I don't want to send anything out there that could fail prematurely. The whole point of these things is that they last pretty much forever, so I won't sell anything that is flimsy. They will come. Anyone that has ordered UCABs already or orders in this buy will be given a special introductory discount when the LCABs are launched.
Group buy end date and date that deposits are required are still to be determined.
These are offered for racing purposes only with no warranty, but I will provide as much support as possible and will replace any parts with manufacturing defects.
Mike in Seattle
Re: Group buy #2- Moosehead Engineering UCABs
Post by Mike in Seattle »
mooseheadm5 wrote:UCABs which are sold assembled will not be fully tensioned. I learned that the preload must be set once the bushing is pressed into the control arm or else there is a risk of the joint binding from being too tight or knocking from being too loose. If they are run too tight or too loose for too long, the races may wear prematurely and require race replacement due to uneven wear.
For those of us that bought a set from the first group, what is the proper procedure for setting the preload once they are pressed into a new set of controm arms?
Preload is probably the wrong term, in that you don't actually want any. You should be able to move the ball with little force, but it should have nearly no endplay. The notches mean that you can only set it in 60 degree increments. I prefer to err on the loose side since tolerances with these seem to shrink when they get hot.
Post by Coldswede »
In case anyone is wondering, the quality of these is A-1, first class, Nice :up:
derrith
Post by derrith »
Coldswede wrote:In case anyone is wondering, the quality of these is A-1, first class, Nice :up:
Seconded and thirded. Have them on two cars now and couldn't be happier.
warezdog
Post by warezdog »
Moosehead needs no qualifiying for me!
You say that you'll have these in stock, is that a for sure or do we need to jump on these within the next few weeks?
I'd hate to miss out and had to ask as the e28 is becoming dracula on my paydays!
I will buy more than what people order in the group buy so I can keep some on the shelf, but if you buy after the group buy you will have to pay more.
Corner Carver
Post by Corner Carver »
Paul, I will take one set of the un-assembled please! :banana: I sent you an email with my order info,
Thanks for getting these going again!! :ohyeah:
ElGuappo
Post by ElGuappo »
This is excellent.
Sets for both cars now...
KatoM5
I missed the first round but I'm in this time.
Post by KatoM5 »
I will email order info shortly. Thanks.
rylee
Ucabs
Post by rylee »
Sign me up for the gold kit Moosehead!....
C.J.
Post by C.J. »
I'm in for a gold set!
Great! Just send an email to buyucabs at gmail.com when you are ready to reserve your order. Not ready for deposits just yet, though.
nell
Post by nell »
Are these good as street application or strictly a track item?
I ask as they appear to be open to the elements, or at least unsealed. Otherwise I love the concept.
They are open to the elements, but that doesn't seem to bother them. I have run them on my daily driver 525iT all summer with no seals and no wear at all. I can obtain some seals designed for rod ends, but you will have to tweak the mounts a couple mm for clearance. If you are interested in those, let me know.
You will notice an increase in NVH, but it is similar to stiff poly bushings, only there is no squeak at all.
Tell all your friends with E24, E28, E31, E32, or E34s!
I want to open it up to people over at Bimmerforums, but I have to look into becoming a sponsor to do it, and don't think it is worth it. Won't know unless they email me back, though. In the mean time, if you are members of other boards (not there, I don't want to cause any trouble) feel free to post about this group buy. Already going over on the M5 board (I got a 1 time pass to do the buy.)
Thanks guys, keep those orders coming in!
TSMacNeil
Post by TSMacNeil »
This is tremendous Paul!...congrats!
I'll save up for a set...still paying for uncovered medical bills...but I'm in... ;)
Post by slammin_e28 »
You can put me down for a set, Paul. I can even roll over and pick them up one weekend with cash money if you like.
This buy will be open for a couple of weeks or so, or I may open it for a while and just order twice what I think I'll need on the old plastic money card. Even if you aren't ready to buy today, send an email to the listed address so I can reserve you a set.
Thanks, guys.
Bimmerforums wanted over $500 per quarter just to allow me to post anything and communicate with members about these UCABs. Holee crap! I won't make that on them!
Corner Carver
mooseheadm5 wrote:Bimmerforums wanted over $500 per quarter just to allow me to post anything and communicate with members about these UCABs. Holee crap! I won't make that on them!
Jeebus! That is Sofa King, we todd did!
warezdog
Post by warezdog »
That seems a bit excessive, especially when you're doing the membership a service, it isn't like you're getting rich off these.
Bump. I am probably going to have to close the group buy at the end of the month. Get those orders in!
warezdog
Post by warezdog »
Put me down for an unassembled set as well
warezdog wrote:Put me down for an unassembled set as well
Awesome. Send your order to buyucabs at gmail.com. i am now accepting deposits at that address.
Manny D.
Post by Manny D. »
Put me down for another set..
warezdog
Post by warezdog »
deposit sent
IRideFixed
Post by IRideFixed »
can i still get in on this? any idea when they will be in the mail?
thanks :D
Yes, you can still get in on it. I am putting the order in right now and will have to wait for their reply on the lead time.
warezdog
Post by warezdog »
When should we expect to pay the other half?
Just trying to budget!
Thanks
