External links now open in a new browser tab - turn this off in your UCP - Read more
here .
E32
Posts: 10 Joined: Sep 18, 2010 7:09 PM
Post
by E32 » Sep 18, 2010 7:20 PM
Hi,
Just getting my turbo install going:
My kpa at idle is just above 60, car is idling at 900 RPM, shouldn't this be in the 40's?
ECU is a VEMS, the car has been on MS2 with the same issue, head has just been restored following a blown head gasket.
turbodan
Posts: 9375 Joined: Jan 09, 2007 10:19 PM
Post
by turbodan » Sep 18, 2010 10:33 PM
Does more ignition advance help?
M30's dont seem to pull as much vacuum at idle as M20's. Its probably nothing to worry about. As long as the engine is in good condition I'd say its normal.
Posts: 15844 Joined: Feb 12, 2006 12:00 PM
Post
by Jeremy » Sep 18, 2010 10:55 PM
60 isn't terribly normal. I don't recall exactly what MAP mine idles at off the top of my head, but I'm fairly certain it's in the low 30s.
Scottinva
Posts: 3663 Joined: Dec 07, 2008 7:32 PM
Post
by Scottinva » Sep 18, 2010 11:47 PM
While I am not turbo, my N/A m30b34 idles at 32KPA. I idle at 22 degrees at 900rpm. It's butter smooth. Do you have a non stock camshaft?
E32
Post
by E32 » Sep 19, 2010 2:35 AM
Thanks guys,
Cam has been set 2 times both following firstfives.org, would a tooth to the wrong side result in higher Kpa?
We'll try higher numbers in the idle setting, is 22 really normal for a M30?
Shadow
Posts: 951 Joined: Dec 28, 2008 10:03 PM
Post
by Shadow » Sep 19, 2010 6:28 AM
27* and 800rpm puts me at 35kpa.
I had it good at 19* and 38kpa, but for some reason
the engine needed more advance as time went by.
Maybe the key on the wheel is bending. idk.
Just keep advancing until it stops getting better.
60kpa is almost ready to die it seems.
Post
by Jeremy » Sep 19, 2010 7:13 AM
Verify your timing marks. You might not be getting as much advance as you think.
E32
Post
by E32 » Sep 19, 2010 7:15 AM
Ok, we're going to try advancing it step by step later today, just need to get the exhaust mounted first.
E32
Post
by E32 » Sep 19, 2010 7:20 AM
Scottinva wrote: While I am not turbo, my N/A m30b34 idles at 32KPA. I idle at 22 degrees at 900rpm. It's butter smooth. Do you have a non stock camshaft?
I believe it's stock. It was repaired shortly after I bought the car, and I've heard no mention of it being anything but stock.
E32
Post
by E32 » Sep 19, 2010 5:06 PM
Tried changing the advance from 14.5 - 25. Which gave zero difference, I'm wondering if we actually have proper control over the VEMS...?
iXer
Posts: 96 Joined: Feb 12, 2006 12:00 PM
Post
by iXer » Sep 19, 2010 6:38 PM
E32: Send me a PM and we can discuss your VEMS installation, I could review your config file.
E32
Post
by E32 » Sep 20, 2010 12:02 PM
Got great advice from Mathias, will try them in a few days time and report back.
marc79euro645
Posts: 516 Joined: Dec 08, 2008 11:33 PM
Post
by marc79euro645 » Sep 24, 2010 9:41 PM
you have to flatten out the area of your ve map at idle
for injection
& also the same for ignition (if your using vems for that)
I encountered this tuning with megasquirt.
if you view it in 3d the idle area would be a flat plateau
marc
E32
Post
by E32 » Sep 25, 2010 3:17 PM
marc79euro645 wrote: you have to flatten out the area of your ve map at idle
for injection
marc
We've tried that, but speaking to Mattias, I'm beginning to understand, we are in deeper problems, than originally envisioned...
E32
Post
by E32 » Sep 26, 2010 8:31 AM
Solved!
Wrong fuel cut settings (60 Kpa), idle doesn't hunt anymore.
E32
Post
by E32 » Sep 26, 2010 1:42 PM
