5 speed swap, clutch canceling the cruise control?
Have gotten everything working except this:
I gotten all the way to the re-wiring part of the job.
I don't see the "clutch pedal being depressed disengaging the cruise control" addressed in the write-up,
and while test driving the car the cruise control doesn't disengage upon clutch depression.
Did I miss something?
There is a small harness under the dash near the clutch pedal with a jumper wire plugged into it. Unplug the jumper and plug the harness into the clutch pedal switch. Viola!
Kyle in NO wrote:Viola!
Yes, and also make sure that the pedal closes the switch when you let off or the cruise won't work.
The donor was a euro without cruise.
Fab time, huh?
It is just a little bolt on bracket and a switch. I'm sure someone can get you one quickly. Andy or Weird Al should have a couple.
