External links now open in a new browser tab - turn this off in your UCP - Read more
here .
mercury26
Posts: 1068 Joined: Aug 08, 2008 2:09 AM
Post
by mercury26 » Oct 15, 2008 7:04 PM
Would it be bad to paint the catalytic converter and pipes with high temp paint? Just trying to get gather opinions on this.
Thanks,
Chuck
Posts: 9522 Joined: Feb 12, 2006 12:00 PM
Post
by stuartinmn » Oct 15, 2008 7:35 PM
I don't know that it would do much good. The paint will probably stick for a while to the pipes, but it will most likely burn off the catalytic converter pretty fast.
turbodan
Posts: 9298 Joined: Jan 09, 2007 10:19 PM
Post
by turbodan » Oct 15, 2008 8:08 PM
I wouldn't bother. It'll just smell funny when it gets hot, and even high temp paints probably wont last on the catalytic converter.
Posts: 17638 Joined: Feb 12, 2006 12:00 PM
Post
by Kyle in NO » Oct 15, 2008 8:53 PM
Don't bother...it wouldn't last 5 minutes in combat.
mogie
Posts: 2575 Joined: Feb 12, 2006 12:00 PM
Post
by mogie » Oct 15, 2008 9:02 PM
The high temp paint doesn't stick for long in the front of the exhaust system (cat and pipes). Smells funny the first couple times you use the car and then only holds up for a couple months before is starts cracking and then flaking. I've had much better luck with everything from the cat back. The center resonator holds up well with the paint and the rear muffler definitely can take it. Even with the "withstands temperatures of up to 1200" blah blah it doesn't. Maybe the paint can physically take the heat but the adhesion just isn't up to the job.
PROJECT. E28
Posts: 1323 Joined: Feb 12, 2006 12:00 PM
Post
by PROJECT. E28 » Oct 15, 2008 11:22 PM
Kyle in NO wrote: Don't bother...it wouldn't last 5 minutes in combat.
i lol'd
Posts: 10735 Joined: Feb 12, 2006 12:00 PM
Post
by Brad D. » Oct 15, 2008 11:28 PM
High temp paint on the rest of the exhaut will probably hold up but I doubt it will on the body of the cat.
ismellfish2
Posts: 1129 Joined: Mar 25, 2006 3:40 PM
Post
by ismellfish2 » Oct 16, 2008 9:57 PM
I don't have a cat, but it appears to be holding up well on the headers, which get really hot, really fast.
Badger
Posts: 623 Joined: Feb 12, 2006 12:00 PM
Post
by Badger » Oct 16, 2008 10:37 PM
powder coating might hold up better . . no?
Post
by Brad D. » Oct 16, 2008 11:07 PM
Badger wrote: powder coating might hold up better . . no?
I don't think powder coating will survive that kind of temp. For similar money ceramic coating makes more sense.
Posts: 27393 Joined: Feb 12, 2006 12:00 PM
Post
by Mike W. » Oct 17, 2008 12:03 AM
Factory cats have insulation between the cat shell and an outer shell. Hi temp paint might or might not stick, but it won't be due to heat.
I've had a silver (hi temp paint) muffler for over 100K now.
