Bryan in SB wrote:Just a quick question. What sort of liability coverage are carrying in offering these wheels?
I am assuming your asking about warranty coverage.
The structure and strength of the wheel is guaranteed for life of that wheel,
under normal and proper usage. However, if wheels are overloaded, excessively abused, exceed the maximum weights, wrong fitting, or re-engineering on the wheel is done without approval, abnormal fitting, or incorrect accessories used on the product, then the damage caused under those circumstances will be excluded from liability.
The paint on all clear coated wheels (These APEX wheels are all clear coated unless a batch of matt black is done) is covered by a two year warranty. This is for manufacturing defects and does not not cover chips or scratches caused by other damage during use.
Most important of all there is $5,000,000 in liability insurance covering their entire product line which as never been used once.
To answer the previous question the facility is in Asia, but is one of the top 5 factories in that part of the world. They produce over 2 million wheels a year primarily for OEM use. They do not use recycled aluminum in their castings and are one of the only facilities that has the flow forming technology (barrel forging) which is similar to what is used by BBS and other performance wheel manufacturers to strengthen their wheel and remove an extra 20%+ in weight off each wheel. These are not cheap cast wheels.
