What do you guys get for highway fuel economy?
And what's your average travel speed? Going out to Toronto last weekend, I got my usual 21 mpg. I set the cruise at 78 mph by GPS (82 on the speedo).
On the way home I decided to see what would happen if I set the cruise at 70 instead, so I did. Achieved 23-25 mpg for the trip home, which is quite a substantial increase.
With the 3.46 gears, the car cruises at ~3100 rpm at 78 and around 2800 rpm at 70. My guess is that the motor is sucking down fuel since it's so close to being on cam, as opposed to being just off cam at 70, and I'd get better fuel economy with a 3.25 or 3.07 at the higher speed.
Or it could just be the fact that at 70 mph I can maintain constant speed without constantly having to slow down for and go around traffic. Which is more likely, any thoughts?
my mileage
I only get about 15, granted, i boost it sometimes during my daily driving, but does the fact that i put bigger injectors in there diminish my gas mileage? I have an A/F ratio monitor in the car and cruising it says i get around 14.7, so does the fact that i got bigger injectors really matter? or is it cancelled out by the fact that I tuned my AFM to compensate.
Re: mpg
You got ~500 miles on one tank of gas?! Tell me I did my math wrong...karl wrote:I got 34.2 on my last fill with mixed driving; mostly highway at 70+mph.
Re: mpg
PSSST, he's probably talking about his 524td with manual transmission.JamusMcFamus wrote:You got ~500 miles on one tank of gas?! Tell me I did my math wrong...karl wrote:I got 34.2 on my last fill with mixed driving; mostly highway at 70+mph.
Or a turbo M21, or a turbo S38, or a supercharged M60. . . I was being facetious.landspeed wrote:Or a turbo M20shifty wrote:Shawn D. wrote:he's asking "What MPG does your E28 with a turbocharged M30 get?"
It was so obvious, too, since the only E28 that would fall under Forced Induction would be a turbo M30.
I'm running 30 lb injectors and have tuned for a slightly lean cruise. Get's 20-21 in the cold with cruise at 78 mph on a long trip, and not making any effort to stay out of the boost. Cruise at 70 and staying out of the boost gives me closer to 24 mpg.
My car has a 3.46 differential, so cruising at 78 puts me at 3100 rpm. This appears to be a rather thirsty area for the m30.
Getting 20+ mpg out of your e30 should not be an issue if you drive conservatively and use the right gears.
