russc wrote:It seems well known to me that the S38s don't last as long as a M30 for mostly one reason, RPM. The S38 runs at higher RPM, so it dosen't last as long. Most get rebuild before 200k, were M30 almost always go past that with the same maintenance level. This would be the same whether theres a turbo or not.
That's a tidy bit of information Russ but it has no bearing on the discussion and is, at least somewhat, unqualified. If we adjust for the M88/S38 final drive (3.91) gearing, the M88/S38 has to go about 180,000 miles to "last as long" as an M30 with 3.25 final drive gearing that goes 216,000 miles. In fact, because of the higher RPM, if road/driving loads were equal, the M88/S38 that goes 180,000 miles withstands more stress than an M30 engine that goes 216,000 miles. Your statement "This would be the same whether theres (sic) a turbo or not" is similarly unqualified and does not withstand scrutiny. It is not correct to say an engine produces 180 hp and lasts 100,000 miles so at 360 hp it lasts 50,000 miles. Quite often, it may last 20,000 miles. As an engineer you know wear does not increase in a linear fashion with stress and fatigue. Triple the stress and it may well result in a part failing instantly. The point here is that it is not possible to make a blanket statement that installing a turbo on an M30 and M88/S38 will result in similar wear patterns to their NA counterparts. But the current discussion and question is which would last longer, an M30 or an M88/S38 under the same extreme load. For example, if called to produce 800 horsepower, would an M30 engine last as long as an M88/S38 engine that was called to produce 800 horsepower? It’s been my position that the M88/S38 engine will withstand the call better than an M30 engine for reasons already set forth.
Due to its better volumetric efficiency, the M88/S38 engine would be running at lower RPM and or boost than the M30 engine to achieve the same work output.
