WTB rear most intake-to-valve cover supporting arm
gwb72tii
Post by gwb72tii »
p/n 11611284749
This is the arm that attaches to the intake manifold over to the rear most area of the valve cover.
DJM1986-5
Re: WTB rear most intake-to-valve cover supporting arm
Post by DJM1986-5 »
I'm fairly certain I have one/several of these - will check the shop this weekend.
fapsifapsfaps
Post by fapsifapsfaps »
Hey just an little question. The supporting arm has two holes for cables. For which cables? I just bought an E24 and the cables are not there.
Thank you!
DJM1986-5
Post by DJM1986-5 »
If e24 has the B34 (vs B35), then these would be for the reference and speed sensor coming from the transmission.
fapsifapsfaps
Thank you very much!
Its an 82' 633 CSI from Japan. They glued the female and male part together. That came loose and the car did not start.
Where can I find the part number from those cables?
Greetings from Germany :)
DJM1986-5
Post by DJM1986-5 »
12141730773 - "pulse generator" ...you'll need two. Consult "realoem.com"
fapsifapsfaps
Tyvm!!
