Hi guys,
My e28 m30b35 has an intermittent bog/hesitation at high revs around 4-5k rpm onwards. Mostly happens in first and second gear.
Does not occur when the car is cold. Have changed the spark plugs, tested ICV, AFM & TPS and all seem to be doing their job.
Any tips on what on what this issue could be?
Thanks in advanced!
Engine hesitation/bog
Re: Engine hesitation/bog
When was the last time you changed the fuel filter? What's the running fuel pressure? Does the AFM put out a smooth curve when moved through its range?
