Turbo ETA build
turbodan
Re: Turbo ETA build
Post by turbodan »
I should do that. I feel like it's running better than the 2007 build did with the blow through AFM, motronic and an undersized intercooler.
If this car ends up for sale, which is the plan at some point, a dyno sheet is a nice bonus.
turbodan
Re: Turbo ETA build
Post by turbodan »
It's been a bit over a year now, I just realized that the other day. Still holding out with this small turbo at low boost, not pushing my luck and enjoying it for what it is. A dirty, dusty daily driver:
I did improve the air filter. I had a paper filter element from a dodge, perhaps a neon, which fit well and I assumed would work adequately. Unfortunately with the moon dust we have out here it proved to be insufficient. It filters out most of it but I still find dust upstream. This is not acceptable, so I constructed this apparatus around a Honda Element/CR-V air filter:
It is a large, cylindrical element consisting of a perforated metal core wrapped with a copius amount of thick, pleated, oiled filter media. The inner diameter is about 81mm and it is open on both ends, necessitating an end cap. I had some straight pull spokes laying around so I used those to hold the assembly together and clamp down against the sealing surfaces on both ends. These are available cheaply at any honda dealer and will support a butt load of air flow. The lightly oiled filter media will catch anything and everything, even better than a high quality paper filter. I highly recommend it.
Re: Turbo ETA build
That should work well! Looks big enough to be a truck filter. :laugh:
turbodan
Re: Turbo ETA build
Post by turbodan »
It's huge considering it's original application. Much more appropriate on something like this which requires far greater air flow than the 2.4l Honda.
I was surprised to find that I had to make adjustments to the fuel table with the new filter. Had to add fuel especially under boost. The old filter was apparently undersized to the point of inefficiency.
I really should dyno it just for kicks. Minimum 230 rear wheel, I would guess 250 max as it sits now at .5 bar. As Todd mentioned long ago, they make a predictable amount of power, something like 11rwhp per pound of boost. I guess the question is what kind of boost I want to run it at. Perhaps .8 bar would be interesting, if the clutch will hold.
.8 bar would be about 11.5 psi. If the predicted power is achieved it would make about 285 rear wheel, comparable to a strong S54. I know this turbo is increasingly inefficient at higher boost but it'll certainly make the boost.
I've also been thinking about swapping the turbo cam back in. That head is complete and ready to install, would definitely make for a more interesting dyno than a re-run of the original.
blue91lx
Re: Turbo ETA build
Post by blue91lx »
I found this thread trying to figure out what flange size the 524td manifold I have sitting on the shelf is. Killer work- this reminds me of old r3v
turbodan
Re: Turbo ETA build
Post by turbodan »
blue91lx wrote: Jul 13, 2024 9:13 AM I found this thread trying to figure out what flange size the 524td manifold I have sitting on the shelf is. Killer work- this reminds me of old r3v
Best to measure it, there are t25 and t3 varieties. The most common is the AGR manifold with the t3 flange.
turbodan
Re: Turbo ETA build
Post by turbodan »
I decided it's time to push my luck a little bit. I figure, if I'm going to swap the head out and put the turbo cam back in, I will be replacing the head gasket either way. Might as well push some more boost through and see how much the stock clutch and head gasket will withstand.
The option at hand is a garrett 12-14 psi wastegate actuator. I removed it from my GT2971R that's been literally sitting on top of my dresser for the last year and bolted it onto the GT2560R. Minor slotting of the bolt holes was required. I prefer this over the ball and spring MBC as the MBC always spikes on spoolup and settles toward equilibrium. A higher pressure wastegate with nothing interfering with the signal line operates more consistently.
The tension on the actuator rod is adjustable, and I may dial it down a bit, as it is currently hitting a maximum of ~175 kpa, or 13.6 psi above atmospheric. This little Garrett is doing the best it can but it does drop off a bit toward the top end, down to about 10.5 by 6k. The pull from the bottom end and midrange is excellent, and despite the drop in boost the top end is not bad either. I don't need to short shift it, it definitely pulls all the way up.
We'll see how it does. The datalog shows only wheelspin, no clutch slippage. This is the same stock 528e clutch that I took out of a parts car about 15 years ago and had sitting on my garage floor until installation late last year. Slipped badly at first, and I was bummed, but after a few drives it came alive again and it's been great since.
Re: Turbo ETA build
How far to the local dyno?
The graph looks pretty solid overall.
turbodan
Re: Turbo ETA build
Post by turbodan »
About 25 miles, hopefully they're still there. It's been a while...
turbodan
Re: Turbo ETA build
Post by turbodan »
Never did get to the dyno, but I do have revised EAE settings. The previous settings worked well in conjunction with significant TPS based enrichment. When I take the TPS based AE out they don't work well at all, so I thought I would try to improve the performance of EAE on its own.
I believe there is an inherent flaw in the EAE code that causes a bit of an issue during warm up. The way I understand EAE, it is calculating a numerical value to represent the amount of fuel pooling in the intake port. It does not factor in what I would call "lost fuel", this is fuel that remains liquid and does not vaporize and combust. This fuel metered by EAE and counted as "fuel on the walls" has in fact been drawn from the port walls and gone through the engine, but EAE still sees it on the port walls.
This is a problem because EAE doesn't work unless you are adding or removing fuel from the wall fuel pool. To add in the required enrichment after a cold start as you drive away, EAE must see a bunch of fuel being added to the walls and it will kick in that much extra to maintain a stable AFR. Since EAE doesn't have a correction factor for "lost fuel", the wall fuel value bloats out of control when cold as EAE assumes a massive amount of fuel is accumulating on the walls. This results in inappropriate corrections in both directions, not enough on tip in and too much correction as you lift off of the throttle. As the engine warms, the fuel vaporizes more readily, the lost fuel factor becomes negligible and the algorithm works as it should. The trick has been finding coolant temp correction settings that make this work without being able to factor in the lost fuel, and I think these settings are about as good as it gets. Moderate throttle movements are recommended, just drive like the engine is cold which you should be doing anyway. When warm, it drives very well with much less TPS based AE than before. TPS AE is perfect for cold starts and low coolant temps, but I don't know if there's a way I can configure it so it provides the necessary boost when cold without providing excessive enrichment when the engine is warm and EAE is up and running.
What a monster to tune though. You can never isolate a variable. Not enough enrichment on tip in is often caused by an insufficient "sucked from walls" setting. If it didn't take enough off of the walls during a gearshift, from the time you lifted off the throttle until you stepped back into it, it will think there's more fuel on the walls than there is and it will apply insufficient enrichment on the next tip in. Balancing added to and sucked from is crucial. Any time the wall fuel total starts to get unreasonably big, it's going to make unreasonable corrections. What constitutes close enough has to be nearly impeccable.
The biggest change in my strategy was to abandon any attempt to maintain a relationship between the "added to" and "sucked from" curves relative to each other. It helps to increase the "sucked from" coefficient at low kpa, you may notice that my curve now bends upward at low kpa. This helps with response on upshifts where it only has a brief period to pull fuel from the walls before it needs to add enrichment again. It should be pulling fuel from the walls, under a strong vacuum the fuel is encouraged to vaporize.
Other than all that, the car has been running great. No issues with the head gasket or clutch, despite having turned the boost up. It was hitting a little over 1 bar on spoolup, but this little turbine is having a hard time maintaining full boost past 5000 RPM. It dips to about .8 bar and holds that the rest of the way up. I am seriously considering a GT2860R or GT2860RS with a .86 AR turbine. Could go with another GT2871R .86. You can feel that boost tapering off and I hate it. Could be stomping a little bit more ass if it were maintaining full boost all the way up.
Re: Turbo ETA build
Thanks for sharing, I will try these settings.
None of my acceleration enrichments have worked well enough for me. I'll give this a try this weekend or early next week and maybe see what it looks like on the datalog as well.
I always seem to have rich on tip wn, though I hD it dialed in ok previously with tps only enrichment. But it's always a bit rich in throttle lift, and has never felt like what I would call snappy for throttle response. Could be related to my intake and intercooler piping length maybe...
turbodan
Re: Turbo ETA build
Post by turbodan »
That's what I really like about EAE, it corrects the mixture continuously to maintain a stable AFR. Adds a percentage on throttle application and pulls some back as you lift off. It has the potential to save quite a bit of fuel, and when it works well it makes a remarkable difference. If you're running 13:1 across the map, a 10% deviation from stoich is no big deal. At 14.7:1 it is a huge problem, but EAE makes it possible. TPS based AE will never work well for slow throttle movements. A whole lot happens below a rate of 20%/sec during normal driving, but at least for me the noise in the TPS signal makes it unsuitable below that rate.
Those settings are working well from about 100-120 degrees on up to operating temperature. At operating temp, they are fantastic. Below 100, I think there is still more work to be done. Yesterday I took a bit of fuel out of the added to walls coolant temp correction curve and cut back the added PW and percentage for cold TPS based enrichment, which was a step in the right direction. I would rather be a little lean than rich enough to misfire, though either option is irritating. There is an ideal balance of WUE and acceleration enrichments and I intend to continue dicking with it until I'm confident that it's as good as it gets. No matter what, it seems that I end up rich at low kpa and lean at high kpa. This may be attributable to the characteristics of the fuel. It vaporizes more readily under vacuum at cold temps, but once the throttle is opened it requires additional enrichment. When the engine is hot, it vaporizes more consistently at all manifold pressures. I would love to find a pressure temperature chart for gasoline, that would be very interesting. The freezing point is about 100 below zero, and it boils at around 150 degrees, but we would need to see a PTC to understand the effect that manifold vacuum has on the phase of the fuel. On a cold start, with the cylinder head at 19 degrees, the fuel certainly behaves differently.
As it sits right now, I added in some extra WUE and pulled back the acceleration enrichment coolant correction factors. The basic EAE coefficients and RPM correction factors are still good, once the temp gauge is into the blue it's starting to run well. I have the EGO control coming on around 75 degrees if I remember correctly, and I've allowed it 8% authority. This may be the way to go, set it up rich enough to drive smoothly and let the O2 sensor handle the rest.
The original turbo car was tuned to run open loop, probably around 13:1 most of the time. It was so much easier only using TPS AE, not giving a shit if it was rich when I lifted off the throttle. Probably stunk to drive behind that thing, running rich with no cat. That won't do this time around.
turbodan
Re: Turbo ETA build
Post by turbodan »
Slight EAE tweaks:
Better still during warm up. I also moved one of the low kpa bins on the SFW coefficient and increased the low end of that curve a little more. Overall it's working great without a whole lot of TPS AE.
I ordered a new turbo too. Got tired of trying not to buy a new turbo, this was the only solution. The price seems too good but it does appear to be a genuine Garrett. We'll see what it gets here. Seller appears to be legit and it is discontinued by Garrett, they might just be trying to get rid of them.
This is the .86 AR variety. I believe that was the same turbine wheel and housing I was running with the GT2871R back in 2007 or 2008. It worked very well, not too sleepy but it had enough capacity to avoid choking up on the top end.
I figure it's about time to put spark plugs in this thing. This set has a few miles on them. I'll be taking the turbo off for that and a valve clearance check and I didn't really want to put the little GT2560R back on. It's been great but its not efficient beyond about 11 psi. Since the stock clutch and fuel pump seem to be capable of at least 1 bar, I'll be running 1 bar. Looking at the compressor map, this thing is capable of making 450+ rear wheel. I would want to go for a larger and more efficient turbine if I was going to push it that hard, though running in the 300ish horsepower range will be no trouble at all.
turbodan
Re: Turbo ETA build
Post by turbodan »
The suspiciously inexpensive GT2876R looks like the real deal. It did not come with a wastegate actuator bracket but I think I can sort that out. The compressor inlet is 4 inches in diameter so my intake plumbing will need work too. I hope the compressor housing clears the valve cover, it's definitely larger.
I used a coffee can here on one of the past builds. Some people didn't like that but I never had a problem with it.
Notae30
Re: Turbo ETA build
Post by Notae30 »
Would you think of using a external gate? or is a internal better for what you are doing?
Notae30
Re: Turbo ETA build
Post by Notae30 »
turbodan wrote: Feb 24, 2023 9:18 PM I've always liked the M20. The M30 is heavier and less fuel efficient. The M20 with the 2.5 top end makes great high rpm power too, whereas the M30 requires more extensive modification for that 6000 RPM+ power. My 2.7i with the GT35R was making peak power at 6400 and it was hanging onto something like 90% of that until 7000. Full boost at 4000 and nothing but fun from there on up. That was probably my favorite aspect of the small six.
As it turns out it's a great motor for boost in terms of durability too. The smaller bore diameter helps avoid detonation and I think the super ETA/2.5 combustion chambers seem to help a little more. I may be mistaken but I think the M30 head gaskets are more delicate. I was doing very well at 21 psi with a stock gasket and head studs. I believe the M30 needs an MLS to approach those boost levels and then you have the usual MLS stuff to deal with. I've had hit and miss results with those, including one that failed only after a buyer had flown in from goddamn Michigan to buy the car and drive it back.
MPG was in the 20s. Best I ever saw was 27. Surely could be better with a more careful tune. This time around I will be using a narrowband 02 sensor for closed loop operation. Easy MPG there.
I know turbineresearch was doing 24 PSI at 560 on the OG headgasket. i love the m20 and the m30. when i do research for the m20 turbo i come looking for your post. turbineresearch m30 info is amazing to if you havnt you should check him out he is a cool guy with alot of info. with the m30 turbo's https://www.youtube.com/shorts/JPQpku4x4Z8
turbodan
Re: Turbo ETA build
Post by turbodan »
Notae30 wrote: Dec 25, 2024 8:34 PM Would you think of using a external gate? or is a internal better for what you are doing?
External works better and is more efficient. Less turbulence at the turbine outlet and a better pressure ratio through the turbine. Internal works pretty well though and simplifies packaging and plumbing. Best ET I ever ran was with the internally gated GT2871R.
The most efficient system I ever had was the externally gated GT35R. Big turbine, external dump on the wastegate. It made boost with minimal backpressure, which improves the intake/exhaust pressure ratio. Higher volumetric efficiency, greater resistance to detonation. I ran a lot more timing with that system than I could with any of the smaller, internally gated turbos.
Turbine efficiency is not often discussed but it is important. Ten percent here makes a significant difference.
turbodan
Re: Turbo ETA build
Post by turbodan »
That big-ass compressor housing posed some challenges, but it does fit. I had to make a bracket for the wastegate actuator and the compressor outlet required clearancing the turbine flange and edge of the manifold. I meant to check valve clearances while I was in there but after all of the unexpected fuckery had been sorted out I didn't get around to it.
The boost comes on around 3000 RPM. Feels very good at .8 bar, stronger especially on the top end. I haven't put a wideband on it yet but I did add in a touch of fuel in case it's breathing better.
It's better in a way that it's not trying to spool up everywhere, all the time. I do have to downshift to get down to business now, no more 1500 RPM spoolup. That's okay though, it seems happier with the larger hot side.
turbodan
Re: Turbo ETA build
Post by turbodan »
It was five degrees this morning on the OBC, -15C if you're so inclined. I didn't expect it to start, the coldest it's ever done was 17 degrees and few degrees makes a significant difference.
It's got mobil 1 15w50 in the sump, better for low temps than the 20w50 conventional I used to run. It still sounded like the starter was working hard though. Cranking time was not excessive, and it lit off in under two seconds. The idle dipped slightly and then stabilized around 900. An ordinary person would never understand how something so seemingly unremarkable could be such a tremendous accomplishment. Cranking pulsewidth, WUE, ASE, cold advance, ICV duty cycle, all dialed in. Time to carve that shit into some stone tablets.
I should have datalogged it. It usually doesn't get that cold out here. Probably won't have another opportunity for a long time. I drove the car last night, it cooled off for about 13 hours outside afterward. I assume the core engine temperature was a little above ambient, not dead cold like it was sitting for a few days. Still, I'm surprised and quite stoked. It's come a very long way since day 1 with megasquirt.
turbodan
Re: Turbo ETA build
Post by turbodan »
Today was another chapter in the book of shit I forgot about and am having to figure out again.
I have been running 2.2ms dwell and 1ms spark duration since day 1 of this build.  With my endless endeavor to refine the driving experience to the greatest possible degree, I'm now in the business of chasing down slight, random misfiring at low manifold pressures in the 2200 RPM range.  I was thinking today about getting another MSD box, which is one option.  Before I go that route, I thought I would screw with dwell and spark duration a bit.
The inductive single coil system is working pretty hard on an inline six.  If I'm doing the math right, at 6000 RPM there is only 3.3 milliseconds available between ignition events.  Megasquirt is pretty cool in that it will run the specified dwell time up until the point which it's limited by duty cycle, and beyond that point it pares down the dwell to the maximum amount available.  I can't remember what I used to run, I do know when I went to the MSD 6A last time I changed the dwell to fixed duty at 50%.  Since this is still all stock, coil and all, I bumped the nominal dwell time to 2.8ms and the spark duration to 1.1ms.  Ten percent more spark duration, in case this beer can of an ignition coil is still maintaining an arc beyond 1ms.  The dwell time begins to cut down somewhere after 5000 RPM, and by 6200 is around 2ms as expected.
It seems to run a little better.  I just had fresh tires installed the other day and was a little bit sad that it now maintains traction in second gear.  With the nearly 30% increase in dwell, it shows slight wheelspin again on the datalog, and it felt stronger from the driver's seat.
Wasted spark would be great, but I don't think I'm ever going to bother with that unless it becomes a matter of necessity.  MSD works, and I like multiple sparks at low revs, but you're still stuck with the distributor and wires.  They seem to sweat a little bit when it comes to delivering 40+kV.  It would be cool to get a cam sensor in there for cylinder identification and more consistent fuel injection, among other things, but if I can meet expectations by optimizing the stock system I'll just do that.
Sebambam
Re: Turbo ETA build
Post by Sebambam »
Cool build , I am also  debating right now to get a  E28 ETA i got offered  with the M20 and the 5 speed to do a BUDGET TURBO BUILD.
what's the reason you stay with the  ETA head and intake compared to switching  to a b25 I head/Intake?
is it purely using what you have?
also about the  Turbo manifold , i saw  you use the TD manifold instead of a aftermarket manifold ...
further i saw you use a turbo with internal wastegate compared to a external gate? i know from  my LS turbo builds  that external gates are much more responsive BUT  the package of the Internal gate  is compact and easy to use ... also your manifold has no  Gate port so you dump it straight  in the Exhaust  via the internal gate,
turbodan
Re: Turbo ETA build
Post by turbodan »
The eta intake was retained initially just to see how it would run. Didn't keep it for long. In it's current configuration it's running the 2.5 cam and intake, which makes a good spread of power.
Internal wastegates are nice for packaging and simplicity. I think an external wastegate would be more efficient. I might go that route again. I was able to run a lot more timing with the external wastegate, tubular manifold and big turbo. Thats the way to go for big power. The diesel manifold can do pretty well though, I've made 300rwhp with them in the past and I don't doubt there's more in it.
The wastegate dump does foil up the turbine outlet to some extent. That can be mitigated if you weld a divider into the downpipe that keeps the turbine outlet separated from the wastegate discharge. At least a few inches of separation downstream would be beneficial. The more the better.
Sebambam
Re: Turbo ETA build
Post by Sebambam »
I consider a internal wastegate myself ,just for the simplicity of a budget build.
a GT30 EBAY turbo like  THIS maybe
what suggestion do you have on the Turbo sizing?
The idea whit the divider in the downpipe is great and easy achievable.
turbodan
Re: Turbo ETA build
Post by turbodan »
Those ebay turbos are a real mystery. If those measurements are accurate, the compressor is plenty big and the turbine is on the small side but will still work.
I would scour the junkyard for a good used Holset, Garrett or Mitsubishi turbo. Better quality parts will be found in the junkyard compared to any of the Chinese mystery turbos.
turbodan
Re: Turbo ETA build
Post by turbodan »
Found this old thing in the garage this evening. I bought it almost 20 years ago thinking I would use it for the original turbo project.
I am fairly certain it's for an e26 M1. I think I had problems trying to find a proper sending unit and I never did anything with it. As luck would have it I found a VDO sending unit for an e30 laying around, so I figured I'd wire it all up and see if it worked.
I supplied 12v to the spade with the pink washer and the signal to yellow. The needle swept downward. No smoke came out, so I presumed that I guessed right on the wiring so far. With the signal from the sensor connected I heated the brass tip with a lighter. The needle rose up to about 75c. I heated it more, beyond the temperature I could hold a finger on, and it read a little over 90c. Good enough to tell when the oil is warm I suppose.
I will have to install this in one of these builds. It's a cool gauge.
turbodan
Re: Turbo ETA build
Post by turbodan »
It's time for a clutch.  This one started slipping under boost in high gears shortly after the new turbo went on.  Subtly at first, the kind of slippage where I can pretend I don't notice.  Today I was datalogging on the way to school and it broke free under boost at about 3600 RPM.  Sounded like the pressure plate was chattering as it tried to grip but spun anyway.  In a regular 528e it would still be good for another 100k miles but in this application it's had enough.  This clutch did slip profusely when originally installed, then started to hook up after it got smoked a few times.  I got another year and a half out of it, not too bad.
I have a beautiful segmented Kevlar Clutchmasters unit that was purchased for the other build, and I still intend to use it for that build, so I ordered another one.  The Kevlar material is green, like the money I piss away on these projects.  Hell of a clutch though, I never had another clutch issue with the original build once I went to the FX300.
turbodan
Re: Turbo ETA build
Post by turbodan »
I just couldn't put another eta flywheel in this thing with the new clutch. Takes too long to drop revs on high rpm upshifts. The heavy flywheel presumably does help mitigate wheelspin in lower gears but I don't think the tradeoff is worthwhile. Rather than spending lots on machine work trying to cut this thing down, I just went and got one of these:
The stock clutch is back to holding the power. As it did initially when I put it in originally, it slipped for a bit, got hot, and then started hooking up again. In light of this development, might as well turn the boost up. Now it's at .8 bar absolute pressure or 1 bar of boost above atmospheric, hitting 95% injector duty cycle. AFR is still good, low 11s, so I can confirm that the stock fuel system can support 30lb/hr injectors with some capacity to spare.
Next on the to do list is definitely the clutch. Though it's hanging in there again it's only a matter of time before it goes slippy for good.
turbodan
Re: Turbo ETA build
Post by turbodan »
New clutch is in, segmented kevlar from clutchmasters. Went with a resurfaced M20B25 flywheel instead of the lightweight unit from TMS. Going to slap that baby into the td when the time comes. Still, the B25 flywheel is much lighter and thinner. Substantially less rotational inertia.
As always, the car feels great after spending five hours working on it in 100 degree heat. The old clutch may have been slipping more than I thought. You don't notice it unless the revs flare, but mild slippage will take away a bit of the kick in the pants feel on spoolup. Its either that or the lighter flywheel is soaking up less of the acceleration and allowing more to make it to the wheels. In any case, it's running great. Excellent engagement characteristics from the kevlar disc, feels as good as any stock clutch ever did.
With the clutch out of the way I have only fuel system capacity holding it back from more boost. These 30lb injectors should be good for about 330rwhp depending on what you would consider a safe AFR. The stock fuel pump is still in there, kicking all kinds of ass. It is able to support these 30lb injectors all the way up to their max duty cycle. I wonder if it can support 42lb'ers. I do have a set on hand...
tigerswaggerman
Re: Turbo ETA build
Post by tigerswaggerman »
Thanks for supplying all this information turbodan!
Question, are you building a td e28 or just using the td manifold on a 2.7? edit: nm you're running the td IM on an ETA.
Why did you use the B25 flywheel instead of the TMS you ordered for this engine?
turbodan
Re: Turbo ETA build
Post by turbodan »
tigerswaggerman wrote: Jul 12, 2025 3:30 PM Thanks for supplying all this information turbodan!
You are correct, td manifold on an M20. Not much eta left in this one, ended up being the M20B25 top end with the super eta bottom. Basically a long stroke version of the B25.
I didn't really know which way to go on the flywheel. I have the other build going on and I essentially tossed a coin on which one was going in which car. If anything I'm planning on going a little wilder with the other build. Bigger turbo, more boost, turbo cam, e21 intake manifold. Seemed to make more sense to me to use the super lightweight flywheel for that one.
