https://www.youtube.com/watch?v=XXqWoCNSiJg
Have you driven the car yet? The BBK intake won't hold any boost. It'll leak on the bottom plate.flywheel86 wrote:1987 535is, LS V8 Swap, Borg-Warner S475 (w/ 83mm wheel), Custom Cam, Ported heads, BBK Intake, Stand Alone Harness / ECU.
Of course not. The lack of posts regarding anything other than turbos is simply due to turbo setups being far more common than anything else.bbaxter wrote:So do you only recognize boost in your E28 club if it comes from a turbo ?
Can you reach out to me ? I have a couple questions about your booster 83 533o. I have the same car and wanna boost but haven’t found any information on it so far. I’d reach out to you but doesn’t give me that optionbornagain wrote: Jun 18, 2014 10:32 AM Im late to the party and havent been on the boards for a while, but....
1983 533i custom turbo setup, garrett gt3571 ms2x air intercooler 18x12x3 60lbs injectors 3"exhaust
1987 325is m30b32 swap, O-ringed, head studs, bullseye performance borg warner s366 turbo, MS3X air intercooled 80lbs injectors 4" exhaust, 625cc W/M
theres way more to list for both but you get the idea.
the 5 series runs 6.5psi boost it was running more but clutch slip and me being a cheap as didnt wanna change it, so boost went down.
The 3 series is running 14psi right now but is built for 28psi last tranny i melted doing a pull(shitty original tranny to be honest though, 260/5 out of 533i donor car with 48*,*** something kms) hoping for over 600whp
Hold up... Your car makes 835 crank HP??euroshark90 wrote: Mar 31, 2023 11:07 AM https://youtu.be/oklZDQW2RIU
Hey guys, my name is Doug. I'm from St. Petersburg, Florida. This is my 1985 635csi 5 speed. I bought this car on ebay sight unseen for $1500 bucks. That was almost 5 years ago, and this car has evolved quite a bit. My main goal was to turbocharge it. Ive had 3 different configurations going from 300whp to eventually going for a max effort build reaching 700whp.
The video I attached was when my car made 557whp@19psi.
Here is a list of my current setup:
1985 635csi turbo 835 crank HP
