I weld
bkbimmer
Re: I weld
Post by bkbimmer »
wkohler wrote:I miss that E3. Where did it end up?
Me too, I have no idea where it is. Another car I should have finished but didn't because I'm retarded.
slack
Re: I weld
Post by slack »
Nice progress Cek. I think you'll find it more gratifying (and addictive) the more you do it.
If you are thinking about buying used when you make the jump to Mig, another machine to keep an eye out for would be a Millermatic 200.
Mine is circa 1991 and I really like it. If you can find a clean one it is a whole lot of machine for the money.
I used mine this past weekend to make a tool to hold the crank pulley while removing / re-torqueing the crankshaft bolt on our 4Runner.
Not the prettiest thing, but it did the job.
Imagetool2
Imagetool3
bkbimmer
Re: I weld
Post by bkbimmer »
slack wrote:Nice progress Cek. I think you'll find it more gratifying (and addictive) the more you do it.
Imagetool2
Imagetool3
Making tools is the best.
Re: I weld
bkbimmer wrote:Making tools is the best.
How ...er, likely homo erectus (NTTAWWT).
bkbimmer
Re: I weld
Post by bkbimmer »
Uncle Leo, HELLO.
Re: I weld
bkbimmer wrote:I weld but also build.
Needs paint.
kzolee
Re: I weld
Post by kzolee »
Welding excercises for beginners:
https://www.instagram.com/dickwally/
Sharkpilot
Re: I weld
Post by Sharkpilot »
I am in the process of buying a MIG as well - think I have narrowed it down to a Miller 211. Keep us updated on your learning curve.
Check out this thread on welding: http://retrorides.proboards.com/thread/119596
This guy knows what he is doing and its on a e28 M5! Also check out his other threads on how to fabricate panels.
Re: I weld
So it seems like even buying used, you’d need to spend at a minimum, $700-$1,000 for anything decent. Assuming I got any good at it, I’m not sure there’s enough welding in my future to warrant the expense.
I might be better off just flying my cousin down from Berkeley when I need welding done. He seems to have the hang of it. :)
bkbimmer
Re: I weld
Post by bkbimmer »
That is nice work.
86GT635
Re: I weld
Post by 86GT635 »
Sharkpilot wrote:I am in the process of buying a MIG as well - think I have narrowed it down to a Miller 211. Keep us updated on your learning curve.
That was a great read. How he made this from a flat piece of steel, I'll never know. That's some skill.
Edit: next page shows he did use 2 pieces on that, but still.
bkbimmer
Re: I weld
Post by bkbimmer »
It's not hard if you have a few special tools, steel is easy to form.
bkbimmer
Re: I weld
Post by bkbimmer »
I made this out of one piece of metal in less than thirty minutes. Patch on my e24 wheel arch.
I put a little more curve in it with my shrink before I welded it on the car.
86GT635
Re: I weld
Post by 86GT635 »
I really wish you'd make a thread on that car, I remember a few years ago you were talking about making a steel front spoiler. Are you serious about closing your shop?
bkbimmer
Re: I weld
Post by bkbimmer »
86GT635 wrote:I really wish you'd make a thread on that car, I remember a few years ago you were talking about making a steel front spoiler. Are you serious about closing your shop?
I close it everyday.
I don't think this crappie e24 deserves a proper build thread.
Re: I weld
bkbimmer wrote:I made this out of one piece of metal in less than thirty minutes. Patch on my e24 wheel arch.
Brent, I will drive up to Oregon with a car full of hookers and a trunk full of beer if you'll fix what I think I'm going to find when I remove the trunk full of beer's seal/gasket. :)
bkbimmer wrote:That is nice work.
Yeah, I don’t how a talentless hack like me could be related to him or his brothers, who are also talented. Maybe I was adopted.:?
This is gate he did for the public swimming pool in Madison Wisconson.
bkbimmer
Re: I weld
Post by bkbimmer »
I don't like beer, you had me a hookers.
Re: I weld
Happened to wander into a pawn shop this morning.
Saw this:
The were asking $899. It has everything that came with it but the manual and 120v power plug adapter. It does have the 230v power plug.
Got them down to $720. Cash back guarnatee w/in 7 days...
Took it home and verified the wire fed smoothly and it made a spark. Yay.
Now to get a gas cylinder and cart for it....
bkbimmer
Re: I weld
Post by bkbimmer »
Sweet, that will come in handy.
Re: I weld
Amazon Prime Sunday Delivery is da' bomb.
This arrived at about 1:30pm today:
https://www.amazon.com/gp/product/B00440DVE4
Assembly took about 45 minutes.
bkbimmer
Re: I weld
Post by bkbimmer »
Where's the Scooba tank?
muleskinner
Re: I weld
Post by muleskinner »
So does this Nobel prize winner. I suppose you could call it "cold irons bound"
Re: I weld
bkbimmer wrote:Where's the Scooba tank?
All the dive shops were closed over the weekend.
bkbimmer
Re: I weld
Post by bkbimmer »
My dive shop is open Saturday.
Re: I weld
Got her up and running. 75/25 with .30 wire. Works wonderfully.
So much easier than the stick welder!
bkbimmer
Re: I weld
Post by bkbimmer »
You're almost a professional.
Re: I weld
I have been collecting ideas from welding table-build threads for years. I finally settled on a design based on @AMCGuy's thread on GarageJournal.com: http://www.garagejournal.com/forum/show ... p?t=180145
His looks like this:
In my case I decided to go with beefier steel (mostly because I was unsure of what to order and decided I'd be better with thicker than too thin). I'm also making mine slightly smaller (51" instead of 60", but still 30" deep and about 32" high). I also wanted more overhang so that I could maneuver around the table easier.
My materials:
Planks: 6" x 1/2" x 30" set 1.5" apart
Long-side horizontal pieces: 3" x 2" x 3/8" angle
Short-side horizontal pieces and legs: 2" x 2" x 1/2" square tube
Casters: Heavy Duty Leveling Casters from McMaster Carr. They look like this:
The steel came last weekend and I've been practicing cutting and welding and dreaming of how the table would get laid out.
I finally got enough clarity in my head to start making drawings. I think I have it all figured out...
The design:
Green are the 6x1/2" planks.
Red are the 3x2" angle iron. Note the one for the top has the 3" side horizontal (where the bolts will go supporting the planks) and the bottom one has the 3" side vertical. The bottom one extends 4" past the legs and will be mated with a 4" section of 3x2" angle iron making a 4x4" base for each caster.
I'm mounting the short-side top horizontal member on the outside so it can serve as a receiver for tools. It will also support two 2.5" trailer hitch receivers facing out the short side (not in diagram).
Probably way more complicated (and stout) than I'll ever need, but the real point here is to have a real project to learn to weld with.
Tomorrow I'm gonna start cutting for realz!
bkbimmer
Re: I weld
Post by bkbimmer »
Way to overthink it.
Re: I weld
bkbimmer wrote:Way to overthink it.
I know, right?
bkbimmer
Re: I weld
Post by bkbimmer »
You are a way more professional looking welder than I am.
