Does BavAuto have them? They're not usually my first go to but I've seen them in their catalogs.geordi wrote:
Bought these nice Hartges from Graham. Picked up from refinishers today. Ronald says sweet!
Now only need new decals for center caps...any recommendations on a supplier?
Really? I've been looking for decals for my Hartge's for several years. Never have seen them at Bavauto (or anywhere else).rmiddendorf wrote:Does BavAuto have them? They're not usually my first go to but I've seen them in their catalogs.geordi wrote:
I bought these off Cactusjacks1 for 29 bucks on this board, Have not used yet as they are slightly smaller, and different color than original ( think he makes):
The rattle over bumps that started a few days ago from the front driver's wheel got worse, so I jacked it up and had a look around.
I must have lost the brake retainer clip over a pothole at some point, and now the 7mm hex pins on the caliper were both backing out from further pothole shaking. Thing was rattling like crazy by now
Tightened them up real nice and grabbed a new clip from the yard. Quiet as a mouse now so I don't sound like a hoopty going down the road
Down the bottom!rmiddendorf wrote:Das_Prachtstraße wrote:Took a photo of it.
Keyless Entry
I added the JC Whitney keyless entry I bought six months ago. Wow, what an easy life-changing job. Another "thanks to myE28" for the endless knowledge base that is this board!
waynet1 wrote:It very well is a huge picture, however, beautiful.Acid House wrote:We climbed up some mountains!
(you can kinda see it perched triumphantly on the far right)
Whoah huge pic...![]()
That would make a great jigsaw puzzle. Difficulty level=extreme.
I will say this; if you think a 528e is slow normally, try taking it to 12,000 ft
Today the '86 535i got the following
Shiny new fuse box cover-super easy to replace.
Shiny new head light/fog light switch support- supper easy to replace (geez these things are flimsy though).
Shiny new brake bomb-Not the hardest thing I've ever done, but man no matter how easy you think a project will be something always creeps up and makes it a pain.
First off the two lines near the firewall would not break free for the longest time. Eventually got them off and the bomb swapped. Then I had almost everything buttoned up and the 19mm high pressure line would not thread into the regulator for the life of me. Ended up having to remove the two low pressure lines and mounting bolts again to get it positioned right for the line to thread. What I've read and thought would take maybe 1.5-2 hours ended up taking me 3. This was my first bomb replacement so maybe I get a pass this time?
Everybody says the rebuild kits don't last for shit. I certainly was not impressed with the quality/feel of the rubber in the one I bought for Maytag. Vlad's a keeper so I don't mind paying for a part that I know will last in a situation like this.rmiddendorf wrote: Why do you dislike the rebuild kit? I haven't done one ever but am interested in knowing why so if I have to I can make an educated decision on how to proceed.
I've had a mystery vibration for a while now. It seems like it started about eight months after getting my tires mounted. I've had them rebalanced a few times now, and it hasn't helped(my rotors are fine).
I have a whole new respect for America's Tire store. I bought my tires there originally and got the lifetime balance option. After the third time back with the same issue, they finally offered to "balance match" my wheels and tires. What this means is they find the heaviest side of both the tire and wheel, and oppose them. Then they do their standard balance. It solved everything. You'd think that balance is balance, but it seems not. It's more work, so I get it that they don't offer it on every install, but in my case, it did the trick. I'll always get this done from the beginning now.
The Bosch ones used to be decent and lasted a few years at least. Bosch stopped selling the insert as a repair kit though, and the repair kit brand available now is shit. If it works at all, it doesn't seem to stay that way longer than a year. Most of the time it fails sooner.cek wrote:Everybody says the rebuild kits don't last for shit. I certainly was not impressed with the quality/feel of the rubber in the one I bought for Maytag. Vlad's a keeper so I don't mind paying for a part that I know will last in a situation like this.rmiddendorf wrote: Why do you dislike the rebuild kit? I haven't done one ever but am interested in knowing why so if I have to I can make an educated decision on how to proceed.
