Post by rmiddendorf »
Bought $1200 worth of spare parts. I'd be the first guy to check with if someone needs an ///M5 part this May... the only thing I won't have is a clutch kit.
rmiddendorf wrote:Bought $1200 worth of spare parts. I'd be the first guy to check with if someone needs an ///M5 part this May... the only thing I won't have is a clutch kit.
Will you follow me on RTT?
I'll be around... :cool:
:up:
Well it looks like I fixed the coolant leak by adjusting the clamp and hose again. It leaked worse after the first adjustment but now it seems fine. I shall continue to keep an eye on it and the hose clamp could be replaced but it seems better now. It was not fully seated on the metal pipe at the bottom. None-the-less those parts are in my spare parts order.
On an additional note it appears that I didn't fry my heater blower motor but that it was the fan speed resistor that went south for the winter.
Mr.3-5-7
Post by Mr.3-5-7 »
Did an oil change with VR1 20w-50.
Topped off all my fluids and changed the spark plugs. It runs soooo much better now with new plugs in it.
I have also been wondering why my brake fluid has been disappearing and i have to top it off every two weeks or so. well i found out today. My clutch master has created quite the puddle underneath my carpet.
Well, that's unfortunate.
AlpinaE24
Post by AlpinaE24 »
Dropped the motor/trans out of a rear ended royal blue 87 535is/5. The drive train is going into a zinno 87 535isA, along with the billy sports
Should be a nice red E28, it is also getting E38 weaves
Cactus
Post by Cactus »
wkohler wrote:Well, that's unfortunate.
BTDT. Very unfortunate indeed. Not all clutch problems are a cracked pedal bracket. :(
Well, when I took delivery of the car, there was a puddle of brake fluid on the carpet. I was prepared to swap the master, but instead we found the feed hose was routed incorrectly after the pedal bracket was repaired, causing it to be chafed and a hole appeared. We changed that and left the master alone since it wasn't very old. Shame that it didn't last. :(
Mr.3-5-7
Post by Mr.3-5-7 »
yeah and whats weird is my clutch feels fine. normal pedal feel and engagement. But when i checked it yesterday, there was about a 1/4 inch of fluid left in the reservoir. One hell of an "oh shit...wtf" moment.
Listened to her whine.
Got my radio back from the Kenwood service center. They found it had a bad output ic (integrated component) which was causing my fuse 5 to blow.
Reinstalled and all good! :banana:
shagrath wrote:Got my radio back from the Kenwood service center. They found it had a bad output ic (integrated component) which was causing my fuse 5 to blow.
That's good news. ;)
grahamular
Post by grahamular »
* Removed ///M badge from trunk lid.
* Applied clear film protectant to new headlights & fogs
* Installed new (brighter) brake & tail lights from Andy.
-Graham
JBort
Post by JBort »
Underhood detailing!
I was so inspired by Mike and Darin in San Diego, I replaced the hood foam, vent rubber covers, washer hose, and washer "Tee"!
Now I can't get it dirty!
JBort wrote:Underhood detailing!
I was so inspired by Mike and Darrin in San Diego, I replaced the hood foam, vent rubber covers, washer hose, and washer "Tee"!
Good man!!!
After St. Paddy's, I flushed the cooling system, added some BMW blue stuff and replaced the water pump just for good measure. I still haven't looked for that little clip that holds the wire for the coolant level to the coolant bottle, I figured I would take Darin's when he wasn't looking. By the way, thanks again for the ECU!
Changed oil & filters for the first time.
I drove the M535. The touring smells like burned stuff, so I couldn't take it anymore. Now its full of tires and I put a couple bars of Irish Spring inside to help minimize the odor.
I should probably start cleaning it up so it can be presentable for Clean Car/Bimmerfest.
DangerWillRbnsn
Post by DangerWillRbnsn »
Finished off the M1.3 swap, and base-mapped the Megasquirt in prep for installation. Hoping for start-up on MS with the first turn.
wkohler wrote:I put a couple bars of Irish Spring inside
Good choice. Manly yet perfect for all-family use.
Wondered if what I was hearing is clutch chatter from the LSD . Checked diff . Plenty of lube , Which is Mobil 1 75 w 90. 5 yrs/ 70k miles. Looks like it was filled yesterday. Does friction modifier wear out? Could be an original CV joint too,or a wheel bearing, I s'pose.
I also noticed a 1/2 " of slack in the throttle cable. The adjustment has been taken up 3/4 already . Should I be looking for the new in the bag, cable , I bought yrs ago ?
B6II is over due for the timing belt service and all that entails. It needs the usual bushings front and rear. Some of my very crude patches have held up , and some haven't. The driver's door needs to be replaced. Or at least the bottom 4 inches of it.
Rust never sleeps .
It is a shame, the drive line has about 160K on it. It is in fair tune and runs well.
John in VA
Post by John in VA »
Clutch slave & master cylinders replaced. Hoping to do the oil pan gasket, CSV hose, and injector o-rings in the next few weeks.
This:
  • Fixing the burned out bulbs in the instrument cluster and headlight/foglight switches
  • Greasing the new odometer gears the PO recently installed that are making that annoying grinding noise.
  • Moving the bluetooth hands-free mic from above the instrument cluster to up by the driver's sunshade
  • Installing the remote display for my new Valentine One radar locator
  • Preparing the wiring for my USB power plug adapter i'm going to install next to the stereo.
Moar details: http://www.mye28.com/viewtopic.php?p=1144775#1144775
pleasefixitup
Post by pleasefixitup »
oil change (valvoline vr1 20-50) and stp filter because thats all I could get... :(
new alternator bushings
cleaned engine grounds
re-tensioned power steering pump belt
fun stuff, did it in a good time too.
Round two of Jack Cavanaugh Clean Car Contest prep on the M535i (Spanish Landing, San Diego 5/19):
Front wheel well cleaning
Front M-Tech Kit, Headlights & Grille cleaning (found a dead Dragonfly that's been there since I think April 2011 :shock: )
Glad you're entering (I assume you are). Clean or Super clean? I would start with clean as it seems under the hood is a crazy endeavor. I won't be entering. Didn't figure I was before, but house go boom and spending several hours a day over there trying to get stuff out (the thieves are more efficient I guess), plus taxes and my usual workload leaves me no time to even put the car together to even make the trip let alone think of entering, so maybe we can have 3 M535s there again.
T_C_D
Post by T_C_D »
Drove 230 miles to N CT. Finally banged 2nd and 3rd gear to 6500rpm. Met some old friends and some new friends for lunch,
533i_Guy
Post by 533i_Guy »
Replaced my power steering pump.
Next is to get the brakes to come all the way back up and not have to pull the brake pedal the last 1/2 inch up. I think if I get under the dash and shorten the return spring a bit it'll be an easy fix.
DangerWillRbnsn
Installed the following:
Motor mounts
transmission mounts
flex disc
center support bearing
e36 M3 shift lever
4.10 LSD (temporary until I get my 3.23)
new crush washers for the power steering pump to stop the leak.
It was a productive day. Unfortunately, the driveshaft still knocks under hard acceleration in 1st gear. :bawl:
