M30 Flywheel FAQ (Motronic controlled)
There are at lease two OEM solid (single mass) flywheels for the M30 Motronic controlled engines. The lighter of the flywheels was original equipment on the M30 Motronic controlled models and the NA (North American) production M5 and M6. The change over production date from the lighter to the heavier flywheel in the M30 Motronic controlled production run was January of 1984, February 1984 production vehicles should/would have the heavier flywheel.
Part number 11 22 1 271 463 is the early / M5 & M6 flywheel and it weighs 7.940 Kg. (17.47 Lbs.).
This flywheel was original equipment on the following models:
NA Production Models:
5 Series E28 Sedans: 533I, M5
6 Series E24 Coupes: 633Csi, M6
7 Series Sedans 733i
Euro/World production Models:
5 Series E28 Sedans: M5
6 Series E24 Coupes: 633Csi, 635Csi, M635CSi
7 Series Sedans 732I, 735i
Part Number 11 22 1 289 244 is the later M30 flywheel and it weighs 10.0 Kg (22.0 Lbs.).
5 Series E28 Sedans: 533I, 535i
6 Series E24 Coupes: 633Csi, 635CSi
7 Series Sedans 733I, 735i
5 Series E28 Sedans: 535I, M535i
6 Series E24 Coupes: 635Csi
Disclaimer:
1. This FAQ DOES NOT ADDRESS CLUTCH AND PRESSURE PLATE FITMENTS.
2. All information contained in this document was compiled from the BMW ETK 1.1.0 dated 20 November 2003 and verified with references current as of 7/28/08 with RealOEM and Maximillains online ETK.
M30 flywheel information
Last edited by Mark 88/M5 Houston on Jul 28, 2008 3:03 PM, edited 5 times in total.
